383 Fluid Harmonic Balancer / Dampner
Old Apr 9, 2006 | 09:49 AM
dflugsta's Avatar
dflugsta
Navigator
Default 383 Fluid Harmonic Balancer / Dampner
I'm trying to remedy a vibration in a ZZ383 and I have heard that a fluid dampner on the ZZ383/425 could make a difference in the vibration I am experiencing; what do you guys recommend for this motor?
Old Apr 9, 2006 | 02:28 PM
C3 Stroker's Avatar
C3 Stroker
Was this motor properly balanced? (Is it new?).....internally or externally balanced ?....need more info....
Old Apr 9, 2006 | 02:54 PM
dflugsta's Avatar
dflugsta
Navigator
It's a brand new crate from GM. Noticable vibration between ~3.5K-4.5K. Externally balanced ZZ383/425.
Old Apr 9, 2006 | 04:43 PM
evalu8r's Avatar
evalu8r
You can't change the balancer without rebalancing the whole assembly. I would call GM and talk to them, maybe a problem with initial balancing or assembly.
Chris
Old Apr 9, 2006 | 04:51 PM
C3 Stroker's Avatar
C3 Stroker
Chris
New motors shouldn't shake (at any RPM).....check warranty with GM.
To 383 Fluid Harmonic Balancer / Dampner
