Help, Lifters Rattling
The lifters were rattling. Is this because they don't yet have oil pressure? Should I crank the motor with the ignition wire pulled to get oil pressure and then fire it? Or did I just adjust them incorrectly? ...I'm kind of afraid to fire it up again without knowing, I don't want to break something.
Here's how I adjusted them. I screwed the poly lock down until I felt resistance. With all the slack taken out, which I believe is zero lash. Then I did a half turn of preload. This all done on the cam base circle. (EOIC) Intake adjusted when the exhaust begins to open, exhaust adjusted when the intake is almost closed.
