Mono-leaf rear spring
Old Apr 9, 2006 | 11:46 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Mono-leaf rear spring
Good evening all,
After much research here, I've decided to swap out my rear spring for a mono-leaf. Though steel has it's supporters, I'm in the mood to try something new,..plus the 35lbs weight savings on my boat won't hurt (how can my figerglass two-seater car be so heavy!).
The favorites appear to be the the springs from VBT and TRW. Two questions:
1) What do I need for a fairly mild 454 car with a basically stock suspension,..a 330 lbs spring or a 360?
2) Which spring is this...VBT or TRW?...and would be good for my rig?
http://cgi.ebay.com/ebaymotors/63-64...QQcmdZViewItem
Thanks in advance!
Old Apr 10, 2006 | 12:02 AM
Warhead's Avatar
Warhead
Call or email VBP
http://www.vbandp.com/
With a bb you probably will want to go with a 360 or bigger
Old Apr 10, 2006 | 05:08 AM
Vesa's Avatar
Vesa
Originally Posted by My White 79
Call or email VBP
Agree!!! Well personnally I would go for steel 7-leaf but if that is not an option...
Old Apr 10, 2006 | 09:42 AM
flynhi's Avatar
flynhi
I've used both VB and TRW springs. I'm currently using TRW on the rear and VB on the front. I have had some issues with VB - one broke and another began delaminating. No problems with TRW. GM chose the TRW design which has a much different cross section than VB.
Old Apr 10, 2006 | 09:57 AM
73, Dark Blue 454
Is that the TRW spring in the link?
Old Apr 10, 2006 | 09:59 AM
flynhi's Avatar
flynhi
It's a TRW type design.
Old Apr 10, 2006 | 10:11 AM
rastadr's Avatar
rastadr
since you never know for sure until its bought and installed my recomendation is the vbp dual mount rear spring. adjustable in 10 minutes from 300-/+700. it also illiminates the need for a rear sway bar. buying it from van steel is less expensive than vbp.
Old Apr 10, 2006 | 06:38 PM
Kid Vette's Avatar
Kid Vette
Be aware that many of us on this forum have had ride height issues with the TRW design spring.
Old Apr 10, 2006 | 06:46 PM
73, Dark Blue 454
Ride height? Isn't that somewhat adjustable by adjusting the bolts on the end of the spring? I've little experience with IRS.
Thanks!
Wes
Old Apr 10, 2006 | 06:47 PM
flynhi's Avatar
flynhi
Kid Vette is correct. The TRW spring does have more arc than the VB and will require a longer spring bolt to get the proper ride height. Depending on your setup, this bolt may be so long as to contact the inside sidewall when cornering hard.
With 15" wheels, I dealt with this with a 3/16" spacer for more bolt/clearance. When I switched to 17" wheels, the spacer was not necessary since the end of the bolt is now inside the wheel diameter.
Old Apr 11, 2006 | 09:46 AM
Jims79's Avatar
Jims79
I just got the TRW 330 mono from the UPS truck yesterday and now I read that it will make my car sit to high in the rear. That's not the look I want. I ordered the 460lb front coils which will/should lower my front end an inch. Not much but my car sits a little lower in the rear then the front and I like the way it looks. If I lower the front and the TRW jacks up the rear it will look like an old hot rod. Plus I don't like the wide TRW spring near my exhaust pipes.
Should I send this spring back and get the VBP 330 or 360 mono.
Jim
Old Apr 11, 2006 | 10:01 AM
Ganey's Avatar
Ganey
VB&P. The rear spring should be matched to the front.
For ex. FE-7 is 550 ft & about 300 rear & the composite should be a little higher- for ex. VB&P replacement rear is 330.
Old Apr 11, 2006 | 11:34 AM
OldSchool's Avatar
OldSchool
Jim
Send it back, that TRW spring will cause you problems.
1. Raises the height of the rearend to look like 4x4
2. Longer spring bolts are needed to lower the rear end, and longer bolts are closer to the ground.
3. Spring will be toooo close to the tire and possibly touch and have potential for blowout. <This is what mine did>
4. I put spacers on to move the tires away from the spring.
Steve
Old Apr 11, 2006 | 11:50 AM
Jims79's Avatar
Jims79
Thanks Steve,
Just got back from the UPS center the TRW is on its way back & I'm putting in the order for the VB&P spring. With the forum discount if will cover the return shipping.
Thanks I'll let you guys know when I install my new suspension.
Jim
Old Apr 11, 2006 | 11:57 AM
73, Dark Blue 454
Boy,..it's good to have this info.
Quick question,..for my 454 car, I'm looking for comfort over a car that will win a slalom race.,..though I don't want a bunch of understeer and 'float'.
Which rate springs (front and rear) will meet my needs?
Thanks again,
Wes
Old Apr 11, 2006 | 11:58 AM
Scottys78's Avatar
Scottys78
Old Apr 11, 2006 | 03:26 PM
77 Vette Girl's Avatar
77 Vette Girl
Can you point me in the right direction for the adjustable rear spring. I just downloaded VanSteel's Catalog and I cannot find the Adjustable version, or any mention of any spring eliminating the need for a rear anti-sway bar. Thanks! It's for a 1977 Model , Wimpy standard spring is just not good enough. I also would like to lower the ride height about an inch. Can this be done with the same kit?
To Mono-leaf rear spring
Old Apr 11, 2006 | 03:59 PM
flynhi's Avatar
flynhi
All vette rear springs are adjustable by installing longer spring bolts and selecting how far up the spring bolt you turn the nut. Longer spring bolts will allow you to lower the rear. Beware of possible contact between the end of longer bolts and your tire sidewall. I used a 3/16" spacer to move my wheels out a bit for more clearance.
Base suspension small block C3s did not include a rear sway bar. Gymkhana small blocks and big blocks did include a small rear sway bar.
If your main vette use is cruising, you will be fine with no rear bar.
Old Apr 11, 2006 | 04:03 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Steve
I had problems with my vbandp spirng about rubbing the tires. But im running 11inch wide tires under stock flares.
Old Apr 11, 2006 | 04:12 PM
11Jake's Avatar
11Jake
I should receive my VBP suspension today. I ordered 550 front springs with the 330 rear Mono spring. Is anyone else using this combo. Is it to stiff, to soft, great, bad. Any installation problems to be aware of.
