I just ordered one as mine is leaking. Do I need to bring the pump somewhere to get the pully pressed on? I assume the pump comes without the pully. Please let me know...Thanks...
The late model Saginaw pumps had pressed on pulleys. These pumps have smooth shafts;i.e. no keyway slot. You should probably think about buying a pulley install/remover tool that is made expecially for this pump. I bought a K&B pulley remover tool. Wasn't too expensive.
On my pump, I have to remove the pulley to remove the pump from the bracket. This is something that pretty much has to be done on the car, hence I went and bought the tool. Actually, i installed a PS pulley last Friday using the tool.
Last time I pulled the pully I vaguely recall using a puller and an impact wrench to get it off the old pump then re-positioning the puller and using a ratchet to press it back on. No impact wrench - don't want to ruin the new pump.
