I have a 76 and the seats seem to recline too far back. Is there an adjustment I can make.
I order the assembly manual and it will take some time to get here. Hopefully it will show.
The interior was redone before I got the car so I am thinking that if there is an adjustment, that it was either left out or is covered.
Does anyone have a piture or can steer me in the right direction?
There are adjustable "bumpers" located where the upper and lower seats meet. However, if your seat frame is broken/bent, you will get that "lowrider" look. There is a metal plate repair piece available in the catalogs for this very situation.
Tilt the seat back forward. There are 2 adjustable bumpers at the rear of the seat cushion where the seat back rests against. Either they are too low or are missing.
The replacement bumpers are approx. $6.00 each. These screw into the bottom of the upper seat back. They allow you to change the angle of the seatback.
The bottom of the seat should have the steel screw that the bumper will rest against.
You can buy a refurbish kit that has 4 bumpers, 4 stoppers, and assorted spacers for the seat pivot. This sells for around $40.00. through Ecklers or Mid America.
Had that problem with my 75. Turns out the nut that holds the adjustable stopper had let loose on the welds. The rest of the frame was bent badly too. Between the bent frame, crushed cushion, and laid back seat back I could barely see over the steering wheel. I tore the seat apart and bent and welded things back to where they should be, along with new seat foam. Now even my 5'2" wife has no problems seeing over the wheel.
