Replacing Harmonic Balancer
Old Apr 12, 2006 | 07:32 PM
redwingvette's Avatar
redwingvette
Default Replacing Harmonic Balancer
What should I be looking for? The stock one is 6.75" dia.
Old Apr 12, 2006 | 07:47 PM
JoeRags's Avatar
JoeRags
I bought a repleacement from the Chevy dealer... there are some nice dampers out there, like ATI, but I didnt want to drop $300+ on a balancer....
go rent the puller/installer from the Pep Boys or Auto Zone when you do the job.. I've heard stories of people pulling the first few threads out of their crank when using the bolt to pull it into place.
Old Apr 12, 2006 | 07:49 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I highly recommend ROMAC balancers! Very light and they are relatively inexpensive compared to other quality balancers! I'm using a ROMAC balancer on my race vette!!
Old Apr 12, 2006 | 07:57 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am happy with my Street Damper by Fluid Damper. Been on the car for over 5 years now and no problems.
Old Apr 12, 2006 | 08:17 PM
jdmick's Avatar
jdmick
All I can tell you is don't buy a cheap import unless you like to time by ear.
Old Apr 13, 2006 | 09:16 PM
Restorod '79's Avatar
Restorod '79
I had to replace my balancer in Jan. Discovered that the old orig. had spun the outer ring, slid back against the timing cover and was burning oil inside the timing cover! Of course this was all hidden from view by the large pulley. I asked around for ideas on replacing it and found that most guys feel that a good OEM is all you need. I got the Summit #161350. I love it! It has a nice finish, well marked scale, and all four 90 degree markings stamped on it. It has made all the valve work and tuning much easier.
Old Apr 13, 2006 | 10:26 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I use an ATI balancer. I had to hone it out a little to get it to fit though. I broke 2 puller/installers during the job though.
Old Apr 14, 2006 | 12:00 AM
Hinz-73's Avatar
Hinz-73
Default ..
Ditto.. My experience as well.
About 60 bucks from Summit.
Do use an installation tool to ensure proper fit.
Old Apr 14, 2006 | 07:31 AM
redwingvette
Thanks,
Summit $50.95
Dealer $140
Local parts store $73
Autozone $83
To Replacing Harmonic Balancer
