Is there a way...
Old Apr 12, 2006 | 10:01 PM
Scottys78's Avatar
Scottys78
Default Is there a way...
Is there a way to get to the power steering dip stick with out having to take the alternator off?
-thanks
Old Apr 12, 2006 | 10:05 PM
jclit's Avatar
jclit
Mine comes out sort of OK. I don't need to remove things to get it out. I remember somebody else had that problem and it turned out that he had the wrong belts on the alt or ps pump and the 2 were adjusted too close together. You should check that out.
Jim
Old Apr 12, 2006 | 10:18 PM
Scottys78's Avatar
Scottys78
Jim
That could very well be the problem
-thanks
Old Apr 13, 2006 | 07:29 AM
Ganey's Avatar
Ganey
This subject has come up many times.
Change PS belt to slightly longer- for a cross reference Gates 7365.
To Is there a way...
