71 BB Crane Cam Hows This
Old Aug 19, 2001 | 02:46 PM
71DropTop's Avatar
71DropTop
Default 71 BB Crane Cam Hows This
Finally found the part # for the cam my builder put in ,It's cam part # 134561
by crane cams.. Tell me what you all think :smash:
Old Aug 19, 2001 | 02:59 PM
trw's Avatar
trw
Default Re: 71 BB Crane Cam Hows This (71DropTop)
Fair idle, performance usage, good mid-range HP, mild bracket racing, auto trans w/ 3000+ converter, marine performance, 3800-4200 cruise RPM, 10.0 to 11.5 compression ratio advised. Basic RPM 3000-6000 PowerMax H-296-2
replacing: CCH-296-2
Cam Specifications
Degrees Duration @ .050 Int./Exh. 236 246
Degrees Advertised Duration Int./Exh. 296 306
Degree Lobe Separation Open/Close @.050" 114
Gross Lift Int./Exh. .571
Old Aug 19, 2001 | 04:11 PM
Lasse's Avatar
Lasse
Hi!
Here's a link to the cam card for your cam.
http://www.cranecams.com/cgi-bin/spe....htm&id=134561
Old Aug 20, 2001 | 01:37 PM
Clai1's Avatar
Clai1
That cam is about 2-steps higher then the cam that I'm running in my '72 454 which is the Crane HMV-278-2A. I like my cam alot but it all depends on how you plan on driving your car.
Old Aug 20, 2001 | 02:35 PM
norvalwilhelm's Avatar
norvalwilhelm
I have a roller comp cam with about the same specs 236 244, 112 lope separation and .623 lift and I find the cam very mild for performance usage. It pulls around 15 inches vacuum at idle and quits pulling around 6500rpm.
Norval
To 71 BB Crane Cam Hows This
