Tremec TKO shifter location solution
Well, I found a CNC company here in Chicago that makes the fuel pressure regulators for GM and Ford, they also make shifters for several of the aftermarket companies like B&M, Pro 5.0, etc.
Anyway, here's their shifter for the Tremec TKO, made of billet aluminum and steel. He sold it to me for $100, complete with two shifter stems, and the billet aluminum shift ball, and the two spacers. With the two spacers and onger bolts, the shifter fits perfectly within the stock unmodified center console. The smooth shift of the TKO is unaffected.
[Modified by Monty, 6:15 PM 8/19/2001]
. Thanks for the help Monty. How's your job hunting coming along ?
What is the company that makes the shifter adaptor? Is it a stock or custom piece?
When installing the Tremec are there any cross member fabricating (say on a 74 4-speed car)? Mechanical or hydraulic throw-out? Did you take any pictures of the modifications required for the install (drive shaft length, U-joints, mounts etc.).
It sounds like a good match for my 3:73's versus a Richmond 5-speed. Do you powershift it (probably not with your torque)? Are they as strong as people say?
I know I am asking alot of questions but it is nice to have someone elses experiences before one starts such a swap.
74vetteman - My 82 has a removable crossmember, so the only modification I had to make was to create an extension for the tranny mount. Compared to the 700R4 that originally came in the car, the TKO's mount is about 3" forward. I just made an adapter plate out of 1/4" aluminum plate. Although I could've used the original driveshaft, with adapter ujoints, I had an aluminum one made with larger, heavy duty ujoints.
454Canam - that black wire is for a Ford neutral safety switch. You can either incorporate it, or you can remove it and install a pipe plug.
