What gears...
Old Apr 15, 2006 | 08:16 PM
jerrylee's Avatar
jerrylee
Default What gears...
Hey guys..with about 2 weeks away from finishing my 454 rebuild in my 77' i'm already thinking about my next project 4 the winter n that is 2 change the gears....right now i'm running the original 3:08's with a 700r4 tranny......what gears would u guys suggest so that i can get that big blast off the line but still enjoy the parkway ride.....thanx....
Old Apr 15, 2006 | 08:27 PM
BKbroiler's Avatar
BKbroiler
Since you've got overdrive and a low 1st gear, go with 3.55 gears. I have 3.73, but no OD. Use a torque converter with about 2,500 rpm stall. Your off the line grunt will be tremendous, when you're not boiling the tires.
Old Apr 15, 2006 | 08:32 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Larry
Old Apr 15, 2006 | 08:46 PM
norvalwilhelm's Avatar
norvalwilhelm
I agree too. 3.55 is a nice ratio but you can even get away with up to 4.11's and still cruise on the expresways. With 411 you are 2200 at 60 and 2500 at 70. Still a good rpm on the highway.
Old Apr 15, 2006 | 08:51 PM
shafrs3's Avatar
shafrs3
But hold off until you get the whole thing on the road. I had a 700r4 behind my big block and couldn't get enough tire out back to hook it up with the 3.08s.
Old Apr 15, 2006 | 09:11 PM
jerrylee's Avatar
jerrylee
Default Gears...
thanx guys....n BK..if it wasn't 4 the hood i would have swore u stole my shark....lol....
Old Apr 16, 2006 | 12:22 AM
Danspeed1's Avatar
Danspeed1
I love 3.73's,... Been from 4.56 to 4.11 to 3.55 to 3.42 and even 2.73,.... on a few of my cars and friends, and with the 700R4 3.70 or 3.73 (depending on your year) is the hot ticket. At 70 MPH your cruise speed RPM is aroung 2400 - 2550. I am surprised that no one else recommended them???
Dan
Old Apr 16, 2006 | 12:27 AM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Shop says I have 3.08's - but my tach reads 3,500 at 85mpg, normal driving on Phoenix Freeways. I would have thought I would be running 2200 or so...
What do you think I have? 3.08? or 3.55's?
Old Apr 16, 2006 | 12:33 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
I've got 3.08s but for the life of me I dont remember what rpms I'm spinning at 85.
I do remember at 55-60 I'm somewhere in the ballpark of 1800-2000
Old Apr 16, 2006 | 10:15 AM
BKbroiler's Avatar
BKbroiler
jerrylee - You must have a sharp looking car.
Old Apr 16, 2006 | 10:44 AM
Glensgages's Avatar
Glensgages
..... with a THM400/THM350 automatic and 27" tall tires, 3500 RPM in 3rd Gear would be 'approx' 83 MPH.....
with 2.73s, a 700-R4 A/OD trans, and a lock-up converter, I turned 2000 RPM at 80 MPH.....
Old Apr 16, 2006 | 11:26 AM
GTR1999's Avatar
GTR1999
308's with 225 70 tires should be about 2500@60mph. Sounds like you have about a 355 gear. You shoud count the turns to see if you cna figure out what you have.
I've been using 336 in BB cars and the guys love it but they are also used in 1:1 final trans ratios.
The best gear sets are Tom's but keep in mind he only has about 200 sets made then they are back ordered for about a year. I have a job in now and the guys wants 373's. I think I bought the last set and they are up to $325-$375 if you can find them. If you can wait get Tom's gears otherwise you have to settle for much less.
Good luck
Old Apr 16, 2006 | 11:32 AM
Glensgages's Avatar
Glensgages
Originally Posted by gtr1999
You shoud count the turns to see if you can figure out what you have.
You are correct, Gary..... we can calculate-and-figure all we want, but the most-accurate way is to count drive-shaft/axle revolutions.
To What gears...
