Tach help needed
Old Apr 18, 2006 | 11:52 PM
supercalvin's Avatar
supercalvin
Default Tach help needed
On my 77 Vette I just replaced the circuit board and the tachfilter.
The needle just sits over on 5000 or so with the key off and engine off. When I turn the key on it slowly rotates to 6000 and stays there.
Did I miss something when I put the board back on? Could the new board be bad?
Old Apr 20, 2006 | 02:00 PM
supercalvin
ttt
Old Apr 20, 2006 | 02:03 PM
kona's Avatar
kona
What was your tach doing before the (fix) the same thing?
Kona
Old Apr 20, 2006 | 02:19 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Did I miss something when I put the board back on? Could the new board be bad?[/QUOTE]
Make sure all the connections are good under the hood...I have seen new boards that are bad but it sounds like a ground issue...check all your connections again. Just for fun try running it without the tach filter before you change anything around again
Old Apr 20, 2006 | 02:26 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
So, tell us .. where did ya get the board? I got mine from Ecklers' and it sucks too
I replaced the filter, still had no tach. Then I went into the dash to reseal the A.C. system and figured I'd pull the speedo/tach cluster out at the same time and fix it. The instructions said to make sure that my tach read 0 RPM when 12V was applied to it. I did, and it does.
But when I start her up, it shows about 650 higher than actual idle speed, and by the time I'm at freeway speed, it's over 1500RPM off. When I get on it, my shift points are 5000-5250RPM but by that time, the tach is way the heck down past the redline, it's at the 6:30 position!!
Funny that we should be writing about this: I got my new summit catalog in the mail yesterday and the book is on my desk right now, open to page 96 where the Autometer Tachs are displayed.
Old Apr 20, 2006 | 09:28 PM
supercalvin
Thanks for the replies
Kona...Yep same thing
Which really makes me beleive that G Dad is right with the ground issue.
I didn't even think to check those wires while I had the dash off.
First I will test without the filter. (I just had to crimp those wires didn't I) D'oh
SanDiegoPaul. Actually it was a Mid America Motorworks, but the filter was Ecklers. I also had to take the dremel to the some of the plastic in there to get to board to set in.
If it wasn't for the turn signal and brake lamp in there I might have looked harder at the autometer sets. I really don't want to rewire them.
Thanks for the help guys.
Old Apr 27, 2006 | 01:24 AM
supercalvin
Fried Tach board!!
Nice black splotch in the corner where two of the compents burnt.
Old Apr 28, 2006 | 08:17 PM
Mike Mercury's Avatar
Mike Mercury
buy boards from John Gardner. They are a quality board and don't require the nylon insulating washers.
contact via email: jtandjudyg@aol.com
Old Apr 28, 2006 | 09:04 PM
glen242's Avatar
glen242
Got my board from Dr. Rebuild. Works fine. There was also a slip of paper, in with the board, that said if the new board did not fix the tach problem, you could send the tach and new board to this 3rd party for a guaranteed repair. The cost for this service was about $25.
Old Apr 28, 2006 | 09:09 PM
Mike Mercury
Doc Rebuild sells the Gardner board
Old Apr 28, 2006 | 11:03 PM
fastvette1's Avatar
fastvette1
Do not check tach without filter. The filter is a capacitor. If you do by pass filter you may burn board up. We have seen this many times in our shop. Pull dash & connect 12 volt tach to tach signal wire & read after market tach. This will check wiring to tach itself.Connect wire to conector which conect to back of dash. Best of luck.
Old Apr 29, 2006 | 02:36 AM
supercalvin
Good info thank you
BUT
I just purchased another one on EBAY for $30
If this doesn't work I will give Dr Rebuild a ring.
Those Autometer gauges look better each time I check out their website.
Old Apr 29, 2006 | 09:57 PM
glen242's Avatar
glen242
Didn't know that. Board worked fine out of box and for the last 2 years.
Old Apr 29, 2006 | 10:07 PM
Kilroy1024's Avatar
Kilroy1024
Originally Posted by supercalvin
Fried Tach board!!
Can you post or PM a pic?
I'd like to take a look at the board.
Old May 6, 2006 | 12:54 AM
supercalvin
Replaced the board (again) and I have a tachometer again.
Reinserting all those lightbulb in there sure is a PITA!
Old May 6, 2006 | 03:39 PM
Kilroy1024's Avatar
Kilroy1024
Those burnt parts are resistors. It looks like R3 is the one that got hot. The bands have faded on R3, but they still look pretty good on R4. R4 got hot just by being next to R3.
In reality, this is not the problem. This is just a symptom of a problem someplace else in the circuit. If you follow D1, you will probably find that the end with the bar goes to R3. What has probably happened is that the other end of the R3 has been shorted to ground. This could happen if assembly into the car shorted the trace to ground, or if D2 (1N5243 zener) shorted out. I would replace D3 with a 1N5245 or 46 before I put it back in a car.
Those resistors are pretty robust components and I wouldn't be surprised if they still work. That circuit board is probably salvageable.
Of course, now that the cars back together, it's a mute point.
(Note: I use lots of Probably's which is the best I can do based on a photo of a circuit)
To Tach help needed
