A/C Removal
Old Apr 19, 2006 | 09:07 AM
Lovin_my_81's Avatar
Lovin_my_81
Default A/C Removal
What do I do with my hoses for A/C compressor if I don't put my a/c back on?
Old Apr 19, 2006 | 09:33 AM
UKPaul's Avatar
UKPaul
I put mine in the attic!
I pulled all the aircon off of my '81 apart from the stuff on the firewall (another job still to do ). If you pull yours off I'd be interested in whether you reckon the steering feels better?
Old Apr 19, 2006 | 10:26 AM
Lovin_my_81
Where do the hoses disconnect? and do you have to plug anything?
Old Apr 19, 2006 | 11:20 AM
UKPaul's Avatar
UKPaul
I just followed them along & disconnected them. I removed the condenser from in front of the rad, a ????? (looks like metal bottle) from inside the p.side front fender & the compressor, along with a few pipes/hoses. May have been a couple of other small bits as well? This left the thing bolted to the firewall with a couple of short lengths of pipe/hose coming from it. I didn't plug anything but I guess you should do to stop internal corrosion. It's quite easy getting it all apart, the most difficult part was getting that thing out from inside the fender (whatever it's called).
Old Apr 20, 2006 | 01:02 PM
davidm_comp's Avatar
davidm_comp
The thing you speak of is the dryer. How did you manage to get a wrench in there to loosen it from the heater box?
Old Apr 20, 2006 | 08:45 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
through the gill...
Old Apr 21, 2006 | 05:46 AM
UKPaul's Avatar
UKPaul
Originally Posted by Avette4me
through the gill...
It's not the easiest of jobs, it's just a bit fiddly. The main problem is that after taking it off then, like anything else you remove, it uncovers something else that needs a bit of R&R
To A/C Removal
