Using Relays
Old Apr 19, 2006 | 02:11 PM
IrishJoker's Avatar
IrishJoker
Default Using Relays
Why and when do you need to use Relays?
Old Apr 19, 2006 | 02:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Good info on one use: http://www.madelectrical.com/electri...adlights.shtml
Old Apr 19, 2006 | 02:34 PM
pws69's Avatar
pws69
Whenever a LOAD (motor, amp, fans, headlights) will be greater than what a circuit can handle.
You turn the RELAY on and off (enable/disable) with the standard switch, and the RELAY switches the power on and off for the [HIGH LOAD] device.
Old Apr 19, 2006 | 02:39 PM
bb69's Avatar
bb69
I have been trying to switch all my high current circuits to relays. Things I would definitly recommend are headlights and electric fans. I would also suggest looking at MAD for more information. One item you may NOT want a relay is the ignition. I put a relay in for my HEI, and the engine wouldn't shut off. The alternator was creating enough of a field to keep the relay energized even when the ignition switch was turned off. There are ways to solve this problem, but I just removed the relay.
Ken
To Using Relays
