Engine is back on the floor.
Old Apr 19, 2006 | 09:04 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Engine is back on the floor.
Well the best I can figure, my vibration is coming from the flywheel. So, I am taking the flexplate and the flywheel to a local engine builder to match balance it. (since 454's are external balanced) Hopefully they will be able to put it on a dyno to check for other vibration issues before I put it back in the car.
Old Apr 19, 2006 | 09:35 PM
evalu8r's Avatar
evalu8r
Let us know how it goes.
Chris
Old Apr 19, 2006 | 09:48 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Keep us posted on the outcome. I must have missed the post that you were having vibration issues.
Neal
Old Apr 19, 2006 | 09:50 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Neal
I didn't say too much about it hoping if I didn't say it out loud, it would go away. It didn't!
Old Apr 19, 2006 | 10:02 PM
MsVetteMan's Avatar
MsVetteMan
Feel the pain man. Deeply. Not a lot of fun to invest all that time into putting an engine in, then having it yank it out. Hope all works out!
Old Apr 19, 2006 | 10:13 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
I was doing the first install about the same time you were having all your problems. I sure hope yours will work out too!!
Old Apr 19, 2006 | 10:57 PM
Cory1970's Avatar
Cory1970
I feel your pain too. I have had engine vibration problems in the past.......no fun
Old Apr 20, 2006 | 12:24 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You shouldn't have a flexplate with a 4sp....just a flywheel
Old Apr 20, 2006 | 04:10 AM
Als70sschevelle's Avatar
Als70sschevelle
3rd Gear
is this flywheel from this motor IE a 454 flywheel or is it from another motor? if it is you have the wrong flywheel. just my 2cent worth.
Old Apr 20, 2006 | 02:52 PM
jackson's Avatar
jackson
It could be a 427 crank (neutral at both ends) ... or it could be an aftermarket 454 crank (some are neutral both ends) ... or it is possible someone had a shop internally balance the stock 454 (resulting neutral both ends) ... or some one may have it neutral on one end and imbalanced on the other ... best to find out exactly what the crank is BEFORE you proceed.
Old Apr 20, 2006 | 10:28 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
The flexplate was from the existing short block that I built. The car is of course a manual that it is in.
To Engine is back on the floor.
