Hood Release Lever
Old Apr 20, 2006 | 10:20 AM
captainmorgan's Avatar
captainmorgan
Default Hood Release Lever
My hood release lever does not return when I pull it. I have to push it back before closing the hood. Is there a spring connected somewhere that pulls the lever back? The car is a '77 coupe.
Old Apr 20, 2006 | 11:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Spring is on the hood release under the hood where the cable connects. It should move back to the closed position after the hood pops up and you release the handle.
Old Apr 20, 2006 | 01:28 PM
Duke94's Avatar
Duke94
There's a spring on the latch part mounted on each side of the firewall. Maybe yours is broken/missing. My 78 and 71' both return when I let go of the handle. All the Vette parts suppliers have replacements.
Old Apr 20, 2006 | 03:13 PM
captainmorgan
Can someone point me to where I can get these springs? I can not seem to find them.
Old Apr 20, 2006 | 04:13 PM
Jerry Curl's Avatar
Jerry Curl
I have the exact same problem. I just thought it wasnt supposed to return.
Old Apr 20, 2006 | 05:47 PM
captainmorgan
me too
Old Apr 20, 2006 | 06:16 PM
Duke94's Avatar
Duke94
Zip Corvette parts
http://www.zip-products.com/Zip/dept...AB6781196375E4
Not sure what year you had so be sure to pick the correct one
Old Apr 20, 2006 | 07:53 PM
captainmorgan
I think I found the problem. I disconnected the cable going to the hood release handle and everything worked fine. Looks like I need to get a new hood release cable assembly.
Old Apr 20, 2006 | 08:06 PM
emccomas's Avatar
emccomas
Did you try lubricating the cable at the handle end?
Old Apr 21, 2006 | 05:03 AM
kb2fzq's Avatar
kb2fzq
Exactly!!....my 76 did this...get a can of WD-40 with the red straw and shoot some up the cable behind the handle...it will make a world of difference...trust me
Old Apr 21, 2006 | 07:52 AM
captainmorgan
Thanks, I will give it a try tonight.
Old Apr 21, 2006 | 08:45 AM
Easy Mike's Avatar
Easy Mike
That works. Shoot some on the end under the hood, too.
To Hood Release Lever
