HELP! Wiper door dilemma!
Old Aug 20, 2001 | 08:07 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default HELP! Wiper door dilemma!
Help please! I have a wiper door where the bolts broke off, and the previous owner drilled them out, and tapped the holes for 1/4-20 bolts.
Whats the problem, you ask? Well, three of the holes are okay, while the back hole one the driver's side was not drilled straight. It works, but it is really half-as*ed, and it bugs me! I am trying to come up with a way to fix it, or an alternate method of attachment to the linkage. Has anyone fixed this same problem? I know that the original bolts are notorious for breaking off when they are attempted to be removed. I don't think a heli-coil will work because it would require me to drill the holle straight, and insert the coil, but one side of the hole would be extra large due to the previous hole. Any suggestions out there?
Later
Bruce :chevy
Old Aug 20, 2001 | 09:08 PM
7t2vette's Avatar
7t2vette
Default Re: HELP! Wiper door dilemma! (7t2vette)
anyone........? :confused:
Old Aug 20, 2001 | 09:14 PM
lyonsh's Avatar
lyonsh
Fill up the hole with JB Weld, then drill it out straight and put in new bolts. Just a thought. :cheers:
Old Aug 20, 2001 | 09:20 PM
Steve Straus's Avatar
Steve Straus
Drill it oversize and back it with a nut? Just a guess.
I haven't looked at my door yet, so I don't remember exactly how they attach. If I think of anything better I'll come back.
Old Aug 20, 2001 | 11:20 PM
7t2vette's Avatar
7t2vette
Any more suggestions out there? I am afraid to try the JB Weld thing, as I am unsure exactly how strong the stuff is. I don't want to drill out the hole and use it only to find it didn't work, and ruining my door in the process!
Old Aug 20, 2001 | 11:27 PM
ScubaJKD's Avatar
ScubaJKD
Post a pick so we can mull it over and come up with some creative solutions. :rolleyes:
Old Aug 21, 2001 | 12:29 AM
69L71's Avatar
69L71
3 solutions:
1) Drill and JB weld a new nutsert (threaded insert) into the hole (I did this)
2) Send the wiper door out for repair. I think Ecklers or one of the other major mail order guys have this service.
3) Get a new wiper door.
Old Aug 21, 2001 | 11:18 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: HELP! Wiper door dilemma! (69L71)
I like the JB weld solution too. It's very strong stuff. Previous owner replaced the lower ball joints many years ago. When they were installed whomever drilled out the rivits missed the mark a couple times. I was driving around with a couple errant holes near the lower joint.
When I re-did my front suspension, I filled those hole in with JB weld. The actual ball joint bolt hole was also slightly enlarged(Bubba). I filled the gap with JB weld and redrilled to the correct size. The JB weld is still there. Strong stuff!
To HELP! Wiper door dilemma!
