Torque Spec's
Old Apr 22, 2006 | 11:10 AM
captainmorgan's Avatar
captainmorgan
Default Torque Spec's
Does anyone know what the torque spec's are for the follwoing on a '77?
Strut bracket to differential
Strut Rod ends to strut bracket
Half shaft to differential
Half shaft to tailing arm
Upper shock mount
Lower shock mount
Shock mount to tailing arm
Old Apr 22, 2006 | 04:53 PM
chris73cpe's Avatar
chris73cpe
According to haynes/chilton:
Strut bracket to carrier- 35 ft-lbs
camber cam bolt- 65 ft-lbs
Driveaxle to diff side gear yokes- 15 ft-lbs(strap or u-bolt)
Driveaxle to wheel spindle flange- 75 ft-lbs
Upper shock mount- 40-60 ft-lbs
Lower shock mount- 50-60 ft-lbs
Strut rod to spindle support- 75 ft-lbs
For the suspension components, put the car back on its wheels before you torque everything down all the way. good luck
