Gotta strange problem
Old Apr 23, 2006 | 02:44 AM
Fubba's Avatar
Fubba
Default Gotta strange problem
When I crank up the 'Vette, it idles around 800 in Park and around 500 to 550 in drive. When I cruise around for a bit, it idles the same in drive or reverse, but when it's put back in park, it idles at 1000 to 1100 rpm...just enough to make it run-on. What would cause something like this to happen? Vacuum related?
Old Apr 23, 2006 | 03:02 AM
TonySinclair's Avatar
TonySinclair
What year? On my carbureted car ('74), when that happens, it means the choke "kick-down" cam is stuck. I move it by hand a few times and it's OK until the car sits again for an extended period.
Old Apr 23, 2006 | 09:42 AM
berger2672's Avatar
berger2672
Cruising
Default Needs oil
Spray WD-40 on the linkage.
Old Apr 23, 2006 | 02:00 PM
Fubba's Avatar
Fubba
I guess I'll try that. Didn't think about it. Year is in the signature along with the carb I have.
Old Apr 23, 2006 | 02:08 PM
TonySinclair
I don't have sigs showing.
WD-40 isn't "thick/sticky" enough to resolve the issue. You'll need something like lithium grease, etc.
To Gotta strange problem
