Starter Removal 1982 Vette -
Old Aug 20, 2001 | 11:36 PM
FLoydC's Avatar
FLoydC
8th Gear
Default Starter Removal 1982 Vette -
Is it necessary to drop the front exhaust pipe on my 1982 Vette to get the starter to clear everything for removal? I unbolted the starter and have it almost free but it is hanging up on something so it won't come fully loose to remove it. Thanks.
Old Aug 20, 2001 | 11:47 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Starter Removal 1982 Vette - (FLoydC)
I suppose that you have the 3 wires disconnected. There is also another nut on the back of the starter that is attached to a small brace that is bolted to the side of the block. This brace will move back and forth, and if you don't have the nut off it will give the appearance that the starter is free, but hung up on something.
If that's not the case, then I guess you'll have to wiggle it around to see if it will clear everything. Sometimes starters can seem impossible to get out without removing something, but usually you can get them out if you hold your mouth just right. :D
Old Aug 21, 2001 | 02:33 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Starter Removal 1982 Vette - (Smokehouse69)
Or when you put your head DIRECTLY under them to get a better look at what is holding them up.
Ask me how I know..... :crazy:
Old Feb 14, 2020 | 07:58 PM
Nitty824's Avatar
Nitty824
Is it necessary to put that brace back on the back of starter.? I left mine off going back in.
Old Feb 18, 2020 | 03:39 PM
Mrvettenick's Avatar
Mrvettenick
Yes, it's there to support the front of the housing. The back part could crack under certain situations.
Old Feb 18, 2020 | 03:42 PM
Mrvettenick
If this is a stock setup, then, assuming the 2 rear bolts are out, and the front bracket is off, you might have to lift the front part a little to get the rear part clear.
BTW, just make sure the battery is disconnected before you start.
Old Feb 18, 2020 | 03:50 PM
speedreed8's Avatar
speedreed8
19 yr old thread. 😳
Old Feb 18, 2020 | 04:04 PM
Mrvettenick
Originally Posted by speedreed8
19 yr old thread. 😳
Didn't look at the date...lol, But there is a post that's current.
To Starter Removal 1982 Vette -
