L98 computer chips tuning
Old Apr 23, 2006 | 03:41 PM
mrvette's Avatar
mrvette
Default L98 computer chips tuning
I give up, I need a chip for my L98 TPI hotrod vette 1227730, anyone on here know of or do chip supplies??
if so, how much and how long??
GENE
Old Apr 23, 2006 | 03:44 PM
Kalway's Avatar
Kalway
Might want to try the C4 section...
Old Apr 23, 2006 | 03:53 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
www.tpis.com does reprograming. Isn't an L98 a speed density system? You may want to look into incorporating a MAF sensor. The MAF system is better at adapting to changes.
Old Apr 23, 2006 | 04:08 PM
wnjlt1's Avatar
wnjlt1
ecklers sells hypertech power chips for that L98
http://www.ecklers.com
then search hypertech power chips
Old Apr 23, 2006 | 04:13 PM
Twin_Turbo's Avatar
Twin_Turbo
DIY! You can never "buy" a correct chip for your car, all those generic chips sold by aprts houses are only a little modified from stock and someone programmig a chip from just getting the specs of the car...I don't think so.
Check out of moates' ostrich will work with your ECM.
Old Apr 23, 2006 | 05:03 PM
GL82TPI's Avatar
GL82TPI
Default Try jimsperformance.com
Try jimsperformance.com, once on the web site you'll be able to find his phone number. Lots of good TPI stuff there. I bought my ECM, wiring harness and chip from him. Very knowledgeable and very helpful. He'll be able to help you.
Old Apr 23, 2006 | 05:15 PM
flynhi's Avatar
flynhi
Try Fuel Injection Specialties in San Antonio, Mark on Hot Rod Lane in Mena, Ark or Fred Wright in Tulsa.
Old Apr 23, 2006 | 05:17 PM
PatsLs1vette's Avatar
PatsLs1vette
Either jims or i used -=jeff=- here on the c4 forum,took a few trys to get it right but when he got it right it was great.
Old Apr 23, 2006 | 06:04 PM
mrvette's Avatar
mrvette
Thanks Pat, as I just sent jeff a note, I am rather reluctant to pay a commercial outfit some 200+ bux for a new chip, but just can't figger out what in hell is rong otherwise....I suspect the programming is/was set for EGR operation, and since I don't have one...well.....
the presence of what the computer thinks is too much O2 in the induction instead of intert gasses, makes for the lean mix, I suspect....
only happens when warm or weather is warm....cooler temps say 60f or lower, runs fine....UNTILL engine warms up....then upon tip in, the O2 gauge says lean to the point of engine misses....I gotta mash hell out of it to run, same thing at light throttle....
GENE
Old Apr 23, 2006 | 07:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Buy an EPROM programmer and drop by www.diy-efi.org/gmecm for instructions on how to tune.
Old Apr 23, 2006 | 08:34 PM
toyvet1's Avatar
toyvet1
Jeff does outragous work, I am lucky enough to have him live ten minutes away. He made two trips over and burnt me about 6 times before it was right. A+++ guy.
Old Apr 24, 2006 | 03:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
Alvin at pcmforless.com is great with TPI tuning. Hes a supporting vendor also. Dont waste your money on the Hypertech chips.
Old Apr 24, 2006 | 05:55 AM
rpoL98's Avatar
rpoL98
I went through the same drill with my '90 IROC (sorry). changed the cam, bigger injectors, better cyl hds, headers, manifold, throttle body, EGR-delete, AIR-delete, etc. I tried a custom mail-order chip but quickly gave up. This whole exercise caused me to buy an el-cheapo used eBay laptop, and some free & some not-free software, and start burning my own chips. it's been worth it, although I had to learn some new technology along the way. I have the 127730 chip, with the $8D "mask". I'd agree this thread belongs in the C4 section. With my custom mail-order chip, I couldn't even back it out of the driveway, nor drive it around the block.
check out TunerPro, DataMaster, Flash-n-Burn, & thirdgen.org under DIY prom.
Old Apr 24, 2006 | 06:41 AM
comp's Avatar
comp
To L98 computer chips tuning
