81 engine freshen need estimate please!
edelbrock performer eps
holley street avenger 670 cfm carb
mallory 85 series hei distributor
no egr no computer
comp cam specs bellow
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 224 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 270
Advertised Duration: 270 int./270 exh.
hooker super comp side pipes with no mufflers(straight pipe)
can some one tell me an estimated hp at the flywheel?
I have a buddy with 1988 iroc z enginge stock only mods are cat back system, hp chip and kn air filter who wants to race do I have a Chance
Please help
A pair of vortec heads + intake manifold will run ya about $700, that'd eat him alive.
His cam's operating range is probably 2300 - 5500. The L82's cam is 222/222 but I don't know the lift on either so I can only guess.
Junking your emissions system and going with electric fans will give you a chance, too.
Espcially the GM vortec heads..........Often ignored, but mostly copied. These are very good street heads!! Make sure you free up your exhaust in order to gain the full benefits of your mods!!
BUT heads are where the power is at. I started out trying to upgrade my stock heads -- most shops wouldn't touch them due to the thin castings cracking when port/polising. Then went on head info search for 18 months reading every article i could find. For heads on a budget, you'd be hard-pressed to beat the Vortecs or the World S/R Torquers. you'd need a different intake for the Vortecs, while the intake you're planning on using would work with the S/R Torquers.
I ended up with the alum AFR 180's so i could squeeze more CR on pump gas, but those 2 above were VERY close flow contenders in cast iron.
Also, what rearend you running?? going from 3.08 to 3.73/3.90 would make your semi-stock motor feel MUCH more powerful....and cheaper than heads
http://forums.corvetteforum.com/show....php?t=1326866
