Vented Gas Cap...Test
Apr 25, 2006 | 10:25 PM
LA Events Coordinator
I purchased a new vented gas cap today for my 75. How does one test to make sure you have a "vented" cap. I was told to check it by putting the cap up to your mouth and sucking air (no jokes please)...then try blowing the air and you shouldn't be able to. Apparently there is a valve that lets air in but not air out....is this true?
Apr 26, 2006 | 12:08 AM
Inside the fuel filler cap is a pressure release valve. This allows it to vent the fumes in the gas tank if they build up to predetermined levels.
could be wrong.....
Apr 26, 2006 | 12:13 AM
So how does one test to make sure you are in fact getting a vented cap.....
Apr 26, 2006 | 12:16 AM
suck on it... just like you said...(the hole on the underside)
I was wondering this same thing a few weeks back.
NHVette was kind enough to go suck on his in his garage for me.
it should also have "VENTED" stamped on the top...
Apr 26, 2006 | 12:18 AM
A GM vented cap will have a small hole (3/32"?) in the middle of the cap on the 'tank side' if that makes sense. Also, shake it,..you should hear the valve rattle a bit.
Apr 26, 2006 | 12:22 AM
Apr 26, 2006 | 12:38 AM
My cap is a screw on and looks like this....
Apr 26, 2006 | 12:44 AM
Quote:
hey i have the same exact one..... but the lock does not work for some reason... does your lock work?
Apr 26, 2006 | 12:46 AM
Yep, my lock works....I do know it's a little squirly
Apr 26, 2006 | 07:09 AM
sorry... mine's old school... same concept though
Apr 26, 2006 | 10:06 AM
Ahh,..if you have a 75 cap or newer it will not be vented.
Apr 26, 2006 | 01:26 PM
Some states check them on a fixture for the emmissions test. Your state may be one. Go to an inspection station and see if this is true.
Apr 26, 2006 | 03:28 PM
Just suck on the threaded end. If you’ve blocked all the other vents out of the tank then you’ll have to take out the valve so that air can come in, and fumes can go out.
