today i got my new breather with nipple, to replace the pcv valve. when i installed it, the motor would die. couldn't keep it running. reinstalled pcv and it purr like a kitten. i know to keep the pcv valve on there and i won't have any more trouble. but i would like to understand whats going on,and why this breather won't work. 76 L48 auto
thanks for any input
russ
no the nipple is for running the same line to the carb it just doesn't have the guts of a pcv valve. it is built like a breather cap with a nipple for the line to carb
That's a wide open vacuum leak. A breather cap like that is not intended to be used with the carb PCV vacuum port - it's intended for use with a crankcase evacuation system. You have to run a PCV if you hook it up to the carb since you have to have a controlled vacuum leak into the carb. Your open breather system needs to be used with a header collector evacuation system or a vacuum pump.
