Spark Plug Reading
Old Apr 26, 2006 | 11:20 PM
Richard454's Avatar
Richard454
Default Spark Plug Reading
Ok...I've had the plugs in for about a year-Have probably driven car 4k w/ these plugs. Engine has about 8-10k on it.
I pulled number one plug after the Hot Rod Power Tour (about 2k of driving in a few days) Plug looked great-tanish color to it.
Car has been smelling rich lately with no changes since trip a year ago except a Carter electric fuel pump(Built-in reg 5-7PSI)-Which I put on the car right after the trip. But no noticable smoke or oil usage.
Plugs one, three, four and eight look a little rich- but then most of the driving recently have been stop and go- no real highway. However... two(the worst), five , six and seven have a BUNCH of crud-hard carbon on them. Why on these plugs and NONE on the others?
Engine is a hyd rolled 327 (about 240 duration) -RPM performer-Brodix Track 1 Alum heads w/ a Speed Demon 575 mechanical-MSD 6 w/ a Petronix II.
These are Autolite 405 plugs-I think I gapped them at .035
Ideas???-I'm going to pull the carb and re-adjust butterflys. It does have the idle-eze adjustment.
THANKS-Richard
Old Apr 27, 2006 | 12:08 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Wow you seriously need to get that car tuned on the dyno. Or at least install an air/fuel mixture gauge so you know how/where the carb is running!
IdleEze won't cure that the carb needs to be rejetted I believe. Also, that looks like oil on 2,5 6 - it's not just a rich carb. My .02
Old Apr 27, 2006 | 12:20 AM
PRNDL's Avatar
PRNDL
wow! Is that the view from inside your engine?
Old Apr 27, 2006 | 12:55 AM
marshrat99's Avatar
marshrat99
Hope I'm wrong but 2, 5 & 7 look oil foiled to me.
Old Apr 27, 2006 | 03:10 AM
Kalway's Avatar
Kalway
WHat happened to 6, too? 3 and 4 look a bit lean, too.
Old Apr 27, 2006 | 10:42 AM
Richard454's Avatar
Richard454
MarshRay-
No, it's not oil- the flash on the camera made the carbon look shiney.
Yes-three does look lean. I'm just stumped at why 3&4 look like they do-and the others are cruded up. It's a dual plane manifold...?
The car on the Hot Rod Power tour got almost 18MPG-
So-I guess I will have to get it on a dyno-
Old Apr 27, 2006 | 11:34 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't agree with 3 and 4 being lean. I like how they look. After a run you should see how white my plugs are and yet plugs last forever and on teardown after 6 years the piston tops were clean and no sign of burning.
I would like all plugs like #3
Old Apr 27, 2006 | 12:14 PM
iNdigo's Avatar
iNdigo
I agree, #3 looks decent, i was always taught a plug like that looks perfect, tan or gray half way back on the anode, fading to black at the base.
Did you pull these immediately after a WOT run, or did you let the car idle before shutting it down?
If you pull the carb, follow demon's instructions for setting initial butterfly position, exposure of the idle metering slot (can't remember if that's what it's called), and take note of your current needle positions (adjusting screws).
If you're certain that you're not burning oil through the rings or valve guides / stem seals, then i agree with the opinion you might invest a few hundred bucks in some dyno time, you may need to re-jet. get someone who can shove a wide band O2 sensor up your tailpipe ( by someone who's certified to shove things up your tailpipe that is) and they'll give you the answers your looking for.
Old Apr 27, 2006 | 12:36 PM
VetteLS6's Avatar
VetteLS6
Default ooomph!
2, 5, and 7 dont look good at all.....stem seals or bad intake gaskets! If it was a carb issue they would be uniform across the board and not random. Any other thoughts on this?
Old Apr 27, 2006 | 09:06 PM
Richard454's Avatar
Richard454
Larry,
That was my thoughts-if it WAS the carb then the plugs would all look the same. I'm seeing the guy that built the motor tomorrow and see what he thinks. I'm thinking intake gasket too.
"Did you pull these immediately after a WOT run, or did you let the car idle before shutting it down?"
I didn't really think that would make a difference because that carbon didn't just get on the plugs. The plugs have black bases-so that might be kind of misleading.
I've pulled the carb- the butterfly position looks like where it's suppost to be. So...new plugs and I'll do a highway WOT run them check the plugs again.
Old Apr 27, 2006 | 09:45 PM
a1sensei's Avatar
a1sensei
Well maybe I'm missing something here, but from what I read, you drove the car 2k miles with no mixture problems, replaced the fuel pump and are now running rich and fouling plugs. Is it just me or is everyone ignoring the obvious. If your fuel pump is putting out too much pressure, it could unseat the carb inlet valve, overfill the float bowl and cause the carb to vomit fuel. Such improperly introduced fuel could easily distribute itself unevenly between the cylinders. You may need a fuel pressure regulator valve. Just my 2 cents worth. God bless, Sensei
Old Apr 27, 2006 | 09:59 PM
Kalway's Avatar
Kalway
Shoulda seen my plugs before I sent my q-jet to lars. They were almost ghosts. Now they're a nice uniform darker tan color all over. I'm still wondering why #6 and #8 look all buggered up.
Old Apr 27, 2006 | 11:33 PM
Richard454's Avatar
Richard454
a1sensei-
"Such improperly introduced fuel could easily distribute itself unevenly between the cylinders."
It's a dual plane intake-and I would guess the plug farthest away from the carb (1-2 &7-8) would be seeing LESS fuel. And there is no evidence of gas running down the carb-sight glasses are half full ( or half empty if you're a type A personality)
When I got back from the trip-I just pulled number one-Which doesn't look that bad now-SO the crudded up plugs could have happened from day one.
The car is still seeing GREAT gas mileage-over 17 a few weeks ago.
Old Apr 28, 2006 | 01:10 AM
VetteLS6's Avatar
VetteLS6
even more thought about that gasket....it could be drawing oil from the intake valley and would better explain the areas of oil deposits (2,5 &7) one thing is it's still a easy fix....if the gasket was the issue you still could get good gas milage...;-)
Old Apr 28, 2006 | 10:10 AM
davidm_comp's Avatar
davidm_comp
I don't mean to highjack his thread, but take a look at these plugs. All my plugs look this way, and I am not sure that this is how they should look. Previous owner put a gm crate 350 (330hp) in the car and put a Edelbrock 1406 600 cfm carb on it, unsure if he ever tuned the car properly.
Old Apr 28, 2006 | 10:26 AM
Ironcross's Avatar
Ironcross
The plugs appear to be fuel fouled. Your stock pump will only produce about 5-6 LBs of pressure. The engine is too rich. The electric pump will normally produce much more pressure on the needle and seat than a mechanical pump. Your best bet may be to install a pressure regulator or better yet, go back to the mechanical pump. A common mistake with the use of an electric pump. If this is correct, you may have fuel in the oil. too.
Old Apr 28, 2006 | 12:55 PM
jdmick's Avatar
jdmick
That's the same exact setup I have. Mine seemed to be running a little rich so I went down the next step lean on the jetting chart and leaned out the idle mixture a little. It seems to run better now. Half of my plugs were fouled before I did this but now they all look great so far. Your plugs look pretty good to me. I'd be curious to know what rods, springs, and main jets your running.
Old May 1, 2006 | 04:28 PM
VetteLS6's Avatar
VetteLS6
Default Gasket troubles?
Any updates on this issue?
To Spark Plug Reading
