Adding stock style
Old Apr 27, 2006 | 01:58 AM
DZRick's Avatar
DZRick
Default Adding stock style
Going to be adding stock style powersteering and have some questions.
Can I use a pump from a 69 Z28 if so does anyone know if the brackets are the same?
I can't find anything about the pumpor brackets in the assembly manual.
Plus is there any way to check the steering box, cylinder and pump before installing them.
Lastly what do I have to be careful of when cleaning and repainting all these pieces.?
Thanks in advance,
Rick
Almost forgot, am I going to have to have the car re-aligned (sp)? and is the manual steeringbox different than the box that was used on a car equipped with power steering?
Old Apr 27, 2006 | 02:52 PM
DZRick's Avatar
DZRick
ttt
Old Apr 27, 2006 | 03:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by DZRick
.....I can't find anything about the pump or brackets in the assembly manual.....
The assembly instruction manual (AIM) will contain an N40/N41 section in Options showing everything included with power steering for those years when power steering was an option. You will find the original part numbers, notes on installation, etc, including the required bracketry. The illustrations are also helpful. If PS was standard on your car, the set up ought to be in the AIM section on steering.
For C3s, all steering boxes are the same, power steering or no power steering. Pitman arms are different.
Old Apr 27, 2006 | 04:20 PM
DZRick's Avatar
DZRick
Mike am I correct in thinking that the assembly manual and the AIM are 2 different manuals?
Never mind, I found it.
Thanks alot Mike. I should know better than to ask questions at 2AM!!!
Rick
Old Apr 27, 2006 | 04:28 PM
DZRick's Avatar
DZRick
Default Still need help with the rest
Still need answers to the rest of the questions guys
Old Apr 27, 2006 | 04:34 PM
SIXFOOTER's Avatar
SIXFOOTER
well, the pump should be the same I would imagine, and if the PS pump on a Z28 goes under the alt on the drivers side it should work. Thats just a SWAG tho, and its free
Old Apr 27, 2006 | 07:43 PM
DZRick's Avatar
DZRick
Thanks sixfooter and free too, good deal
Still a couple unanswered I know some ones got the answers.
1) Is there any way to check the steering box, cylinder and pump before installing them.
2) What do I have to be careful of when cleaning and repainting all these pieces.?
3) Am I going to have to have the car re-aligned (sp)?
Thanks for the help so far guys
Rick
One more 2 part question...... Seeing as my ideler arm and tie-rod ends are new on the non-powersteering setup can I use them on the power steering or are these parts only good for either or?
Old Apr 27, 2006 | 09:17 PM
72LS1Vette's Avatar
72LS1Vette
Easy Mike says the Pittman arms are different. Can't confirm or deny that. The tie rod ends should be the same. The Corvette power steering components aren't that expensive, compared to some other Corvette stuff, so unless you have free parts lying around you would be better off buying the correct parts from someone like Vette Brakes.
Rick B.
Old Apr 27, 2006 | 09:23 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Rick B.
The pitman arms are different and cannot be exchanged. YOU CANNOT USE A MANUAL PITMAN ARM ON POWER STEERING!! I found this out the hard way. I had my car on jack stands and was testing out the new power steering. I had just converted from manual. The steering was okay in one direction, when I started back in the other direction, the wheel whipped out of my hands and went to full lock. If I had been driving the car, I could have wound up in the ditch or in a head on.
Old Apr 27, 2006 | 09:57 PM
DZRick's Avatar
DZRick
Default Rick B.
I've been throwing money around pretty good lately
I see the component kit ( valve, cylinder, hoses and fluid )for $230.
I'm thinking a correct bracket for the pump I should be good to go.
Thanks for the help gentlemen.
Old Apr 27, 2006 | 10:01 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Go Jeep Box. Don't mess around with the 50s-design dino-tech power steering.
To Adding stock style
