Automatic Shift indicator
Old Apr 27, 2006 | 01:47 PM
kazco's Avatar
kazco
Default Automatic Shift indicator
I have a 76 with automatic. This is my first Vette, should there be an indicator showing (red needkle or something) what gear I'm in? There are dots by the shifter but nothing under the plastic lens showing if I'm in neutral, park, reverse, etc.
If there is, does anyone know where I can get one?
Thanks,
Mike
Old Apr 27, 2006 | 01:55 PM
bluesilver82's Avatar
bluesilver82
I have an 82. My shift indicator is white. Remove the side cover panels to the center shift console and see if the plastic indicator has come loose and fallen. If you can't find it, then Mid America, The last detail, or Year One would probably have one. There is a good chance you could find one on ebay. All of the companies listed above have websites. Do a google search. Good luck.
Old Apr 27, 2006 | 02:01 PM
kazco's Avatar
kazco
Bluesilver82,
Thanks, I thought there should be. I'll have a look this weekend.
Thanks again,
Mike
Old Apr 27, 2006 | 04:12 PM
Higs's Avatar
Higs
Passenger side cover panel, pull back and you should see it hanging down or broken. Carefull, very fragile.
Old Apr 27, 2006 | 06:00 PM
rodesmg's Avatar
rodesmg
Thanks,
Mike
i have a 76 and i don't have a indicator, i think they were made that way
Old Apr 28, 2006 | 03:53 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You would be incorrect. It was there, it's probably slipped off or broken.
My experience is that the repop needle doesn't fit...but that was 10 years ago. I found the original inside the console, painted it orange, and reinstalled. Still there. I think one of the Previous Idiots knocked it off the shifter during some Bubbafication.
Old Apr 28, 2006 | 05:26 AM
rodesmg's Avatar
rodesmg
i can't seem to find one in the catalog or on line maybe you can point me in the right direction for a 76 on my 76 on the left side you have chrome lines you line the shifter with, and on the right side you have prnd . they sell a needle for 77 but not a 76.
Old Apr 28, 2006 | 09:07 AM
bluesilver82
http://www.corvettesalvage.com/index.html Try this place.
To Automatic Shift indicator
