What are the problems with the early C3 steering setup?
I have a fully restored vette, and the steering leaves alot to be desired. Specifically, at high speeds, the car feels very 'darty' or 'nervous' for a lack of better terms. What causes this? Is it a lack of positive caster? The entire steering set up itself? High front end lift? What can be done to correct this situation? Switch to a rack and pinion set up like Steeroids? How exactly does that 'bump steer kit' from VB&P work anyways? What does it do,and where does it bolt onto? Sorry for all the questins, but I want to fix this to a tolerable level. My DD Cavalier handles better at high speeds!
Replace rag joint, idler arm, tie rod ends. Replace or rebuild steering box. Increase caster. You can decrease the steering quickness by connecting the tie rod end links to the inner hole at the front wheels.
I had the same problem, I decided to switch to the steeroids package, and also swapped front tires from 255/60/15 to 225/70/15. Car handles very nice now, better than I expected.
Like I already stated, the car is fully restored, 100% new everything, a body-off. The car also has a VB&P complete suspension package, and has been aligned to their specs. I just installed the VB&P tubular upper control arms that have 5 degrees of positive caster built in, just wondering what else i can do while it is apart. With power steering, you are not supposed to use the other hole in the spindle for the tie rods.
The car has 255/50/17 tires all around. I have had other cars with tires this wide out front, and they did not exhibit these symptoms.
I'm not sure you are ever going to get the feeling that you get with a new car unless you go to the rack and pinion setup. I have the same setup as you and the real problem is that power steering back then was really power. My car had heavy steering when I had a bad power steering pump and it felt good at high speed. Then I fixed tha damn thing with an AGR pump and I can probably drive with my little finger now at speeds over 50. I do find that the VB&P setup makes for quick response which, depending on how light the steering already is, makes for a darty feeling. I'm thinking of having a little more toe added as per VB&P instructions to help the matter. But I don't think it will ever drive like my 350Z. Maybe that's not so bad though. Part of the fun of these old cars is seeing what it felt like to drive back in the day.
Why don't you try and play with some different caster, camber and toe settings first to see if you can settle it down. You may be worse off with a power rack or jeep box if they provide too much assist. There have been many complaints here about the racks. Its a crapshoot on what valving you get in these racks.
Thats what I am going to start with. I just installed these VB&P upper arms, the pic shows how VB&P achieved the additional positive castor by moving the ball joint towards the rear of the car; these are the drivers side arms:
Next I am going to adjust the tie rods one turn in for a little more toe.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine is really stable at high speed, I love it, nothing to worry about, I could take a nap it's that relaxing.
Maybe your front end is lifting, I remember my CUda was an experience to drive at high speed, it had standard steering which felt like power steering at high speeds which meant the front was lifting
Yes, I do believe that is also a problem, front end lift. Its a known problem with the early sharks, if you look at a pic of early C3 race cars, they always have a big front spoiler to deal with this. Later sharks like yours have a much bigger frontal area. I might have to fab up a custom front spoiler. I guess it also doesn't help that I took 100+ lbs off the front end through the extensive use of aluminum parts!
These will help but it is not the cure. c3's were doing 200 with stock a-arms back in the day. Although they had alot of mods done to them.
I have steeroids rack and pinion on my car and it handles well. I have increased effort to steer, which I wanted, as I could previously turn the car without any effort. I have found it to be stable until 80-90MPH but I also haven't spent much time doing an alignment.
AS for problems with your existing system, there are multiple points of slop in the system, rag joint, steering box,control valve and tierods and balljoints. Even though everything may be new or rebuilt, there may be enough combined slop to create the vague feeling you experience at speed.
I don't think I have explained what I am talking about properly. My steering doesn't feel vague or sloppy. At high speeds, particularly over a rough stretch of pavement, it almost feels like there is too much assist, making the steering feel darty. My car is lowered, and I am thinking that this is called 'bump steer', but I am not sure. Also, the high speeds I am talking about are speeds in excess of 130 mph.
Wow, look at differences in the size and shape of the frontal areas between early and late C3's. My car is lowered, and look at how much space there is between the ground and my front spoiler compared to yours:
Did you follow the guidelines from VB&P that they list here? As they say here at the bottom of the table.
Advanced Street - These specs are designed to give an even quicker steering response with minimum tire wear. If the car is "darty", toe the car in. By toeing in, you may loose some turn-in qualities gained by the initial specs.
