Tach Filter
Old Apr 28, 2006 | 01:17 PM
alotaball's Avatar
alotaball
Default Tach Filter
Just curious.. I relized there is no tach filter on my 79 .. when i went to hook the tach up .. it works .. but the rpms are off... idle shows 2500 and a slight bit of gas it will rev up and peg ... so will a tach filter solve this ...and .. is there any way to make one myself instead of waiting for shipping and all of that .. thanks
Old Apr 28, 2006 | 01:41 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Do a tach filter search here in the forum... a lot of info on this subject there
Old Apr 28, 2006 | 01:59 PM
alotaball's Avatar
alotaball
but the way my tach is responding .. is that the result of having no tach filter ..
Old Apr 28, 2006 | 02:02 PM
G dad's Avatar
G dad
It is a possibility I think I have a schematic u can build for about $2...taking a look for it right now
Old Apr 28, 2006 | 02:17 PM
alotaball's Avatar
alotaball
i found it ... but i also found a lot of threads were people bypassed it and it still functions... I would still put one for precautionary reasons .. but .. i am wondering if this is going to fix my problem or if it is something beyond that .. that is wrong
Old Apr 28, 2006 | 02:25 PM
G dad's Avatar
G dad
Good idea you should have my e mail address...send me a note I will ship off a diagram of a filter you can build...check all your connections the connector at the distributor can make it's way loose & cause problems..
Old Apr 28, 2006 | 02:57 PM
alotaball's Avatar
alotaball
well when i bought the car ... it was not hooked up .. so i hooked the wire up to the tach .. marked on the hei .. and it came to life ... Just way off.. the idle is smooth as glass .. has to be in the 800 rpm range... and it shows that is at somewhere near 2000..
Old Apr 28, 2006 | 08:15 PM
Mike Mercury's Avatar
Mike Mercury
Old Apr 28, 2006 | 08:51 PM
Kilroy1024's Avatar
Kilroy1024
First the schematic:
The tach itself right has adequate filtering to protect against high voltage transients (D1, R3, C3, R4). Putting the tach filter (R1, R2, C1, C2) in front of the input filter does not provide much additional protection. However, it should do a pretty good job of stripping off any RF noise that could interfere with the radio.
I think its unlikely, but possible the tach filter is the source of your problems. A change of Tach filter has often helped when the tach didn't work at all because the filter was open circuit. I don't recall too many cases of an erratic tach being fixed by a filter change (in the last year that I've been watching). Try putting in a quicky filter with R2=10K and C2=100nF. And yes I mean just the two parts. Its so close to the "real" filter that If that doesn't fix it, a new filter won't either.
Good Luck
EDIT- Looks like Mike beat me to it!
Have to learn to type faster......
Old Jun 9, 2006 | 12:07 AM
molchaser's Avatar
molchaser
Default Tach Filter for a 78
I have been looking for a replacement tach filter for my 78 at Autozone, O'Reillys, etc and can't seem to find one. Do they exist or is there a suitable substitute I can use?
The radio whine is fierce and seems to come through even with radio off
Thanks for help (as always)
Ken (molchaser)
Old Jun 9, 2006 | 01:29 PM
C3 4ME's Avatar
C3 4ME
My 79 does exactly the same thing. indicated 2000 rpm equals about 1200. I also do not have a tach filter. It shows about 4500 going down the interstate.
Old Jun 9, 2006 | 02:02 PM
TopGunn's Avatar
TopGunn
Mine was eratic above 3,000. It would fluctuate all over above that RPM. I bought a new filter from ZIP and it works flawlessly now, smooth as silk. Mine was original and was just an electrolytic capacitor, since then they've been refined as the above schematics show.
Bill
Old Jun 9, 2006 | 02:05 PM
C3 4ME's Avatar
C3 4ME
topgunn, would I be able to disconnect the tach wire from the distrubutor and then put the tach filter inline between the tach wire and the distributor without cutting or splicing any wires? In other words, does the wire going to the tach output plug into the filter, then the filter into the distributor? I dont' want to cut any wires to install one inline.
Old Jun 9, 2006 | 03:30 PM
Hvymtlc5's Avatar
Hvymtlc5
found one at a salvage yard off an old Camaro or something.....cost was free...(yeah, they gave it to me - didn't steal it).
Old Jun 9, 2006 | 03:53 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Another reason your tach could be off is the tach board. Aftermarket import tach boards don't work properly.
Old Jun 9, 2006 | 05:35 PM
TopGunn's Avatar
TopGunn
It's a series connection, yes you have to put it in line with the distributer and the tach, also the capacitor has to have a ground attachment. But you could rig it up temporarily as Kilroy suggested to see if it makes a difference. You could use some aligator clips with wires and wire in the circuit without cutting anything. You can get the parts he mentioned from radioshack along with the aligator clips if you don't have them.
Bill
To Tach Filter
