I was talking to a friend out at work the other day, and his car has overheated and blown some gaskets. He was wanting to trade it off and he told me that this dex cool that he had in the car may have ruined his engine, [Buick Lesabre v-6 2000 vintage.] He said there are consumer alerts and lawsuits against GM about this anti- freeze. Anyone have the skinny on this? Is this the only thing available now? I am considering flushing my vette and don't want something in there that is going to cause more trouble than it is worth.
Interesting. I just switched to Dex cool in my new motor. I ran Prestone for years. I have had 2 GM vehicles that went 90K miles with never changing the anti squeeze for 3 years. Never had a cooling issue. What have others experienced?
BS. I've been running Dex-Cool in my 71 for 7 years now with no problems.
So have I. I started using it when I originally put the motor and new radiator in it so there was no mixing of the dex cool and the "green" stuff. I hear that's what causes the problems.
There's a known issue with GM trucks and Dex-cool. It's not dex-cools fault. The trucks that have problems had bad radiator caps and angled filler necks. This combo let air into the cooling system and dex-cool does not like air (it forms sludge). With no air in the system it's fine.
There's lots of issues with GM trucks and dexcool, ask your local chevy dealer about the intake manifold problems they are having with them. Also try and find a 3.1L or 3.4L gm engine running dexcool that doesn't have an intake manifold leak (internal or external) and is over 5 years old. I probably change out a dozen of these a year, compared to maybe one or two with the old green stuff. I'm not nescessarily saying that dexcool is at fault in all these cases but it's has become far more prevelant since GM changed to it. Enough so that the gaskets have all been revised here in the last two years to combat it. I think a lot has to do with the change interval they are recommending, I think by the time it makes it to 5 years the stuff is already eating through the gaskets, I recommend to all my customers to change it every 3 years. I don't see much advantage changing to it over the old green stuff given that it's far more likely to gum up in the presence of oxygen and cause more problems then it's worth. I think changing the old green stuff every other year is a far safer way to go, albeit requiring more maintenance.
Pat Kunz
Been changing out bad dex cool gaskets for a while. I mostly change gaskets in trucks, 3.1 and 3.4's. I don't know if it is the dex cool or the set up, but I take dex cool out of every motor I can just to be sure. I have only worked as a tech for a year, but I have already seen the problem many times over.
In my service shop, I see no failure problems associated with Dex-Cool vehicles. Most of the intake leaks (gaskets and intake erosion) we see the coolant is green (the older stuff). All late C-4's and all C-5's we see using Dex-cool have very clean cooling systems. No evidence of Dex-cool failures as far as I can tell.
I have a 2000 GMC Denali and I have had two intake gaskets changed under warrant and now need another one out of warranty. Is this vehicle using the dex cool stuff? Is there a recall on this?
In my shop we get at least 4 3.1/3.4 intakes a week along with the 5 or so 5.7 Vortecs. Apparently dexcool hates air and can get corrosive when exposed. I am not opposed to Dex-cool but I would not run it in my car. There are some new coolants out there than will mix with anything and do not have the corrosive properties that Dex-cool does. I see too many GM vehicles needing major work way too soon.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
My mother in law has a little Malibu that needs to have the anti-freeze flushed and changed out. I told her to bring it to me and I would change it for her. Any suggestions on what to look for when it comes time for me to start dinking with the car as far as problems. Also what should I put back in the car as far as coolant goes? I am afraid of working on other folks cars because of opening a can of worms.
eddie 70 look for a few things if it is the 3.1/3.4. Sludge in the tank caused by oil getting into the coolant. A leak on the driverside of the intake on the trans bell(90% will have this leak from my expirence)may be light. Also remove the oil cap and look for cream.
I still don't see what bad intake gasket design has to do with dex-cool. There are tons of other engines running dex-cool that don't have any problems.
