Looking For Help Diagnosing Engine Miss
Old Apr 30, 2006 | 10:51 AM
75SHARK's Avatar
75SHARK
Default Looking For Help Diagnosing Engine Miss
Hello,
I have a '75 with the L82 engine. My engine has developed a miss, which I can only feel from idle to about 2,000 rpm. When I punch the gas, it goes without missing at all, so I don't think its a fuel problem. I don't feel the miss going down the interstate (at steady higher rpm's) I have a newer Edelbrock quadrajet carburetor and the plugs, wires, cap and rotor are about a year old. I have the timing set and idle mixture set correctly (as far as I know). All of my vacuum hoses and headlight system is new, so I don't think there's a vacuum leak. I don't detect any vacuum leaks around the carburetor as well. I took out a couple of the plugs and they look fine. I'm not sure where else to go other than just trying a new set of plugs and wires and seeing what happens. Or I may just take it to a shop and have it hooked up to a diagnostic machine. Is there anything I'm missing? Thanks!
Robert
Old May 1, 2006 | 12:57 AM
Thmprr's Avatar
Thmprr
My '76 behaves like this, and it's a wiped cam exhaust cam lobe on #8, it misses until about 2000 rpm then it's hard to tell it's missing. Checked this out by comparing the lift on the valve spring retainers with the valve cover off.
There's a lot of cam wear happening at present due to the oil companies removing zinc as an additive.
Old May 1, 2006 | 01:29 AM
wombvette's Avatar
wombvette
Usually a vacuum leak on the 5/8 runner. There is a vacuum fitting there that supplies the headlights, wipers, brake booster etc. a leak in any one of these systems makes 5 and 8 lean. At normal speeds or full throttle it is not apparent, but will miss at idle.
Old Jun 14, 2006 | 09:12 AM
77 zz4's Avatar
77 zz4
I had the same problem. For me, I believe it is a brake booster vacuum leak. When I plug it with my finger the car runs fine. I'm going to replace them this week.
Old Jun 14, 2006 | 09:18 AM
PhotoVette1's Avatar
PhotoVette1
You could also have a stuck/sticking mechanical advance. I had the same problem on my '77 and that is what it was. Pull the distributor cap and lubricate it and make sure its free.
Old Jun 14, 2006 | 03:27 PM
BLUSHRK's Avatar
BLUSHRK
Not to sound like Captain Obvious, and not to insult your intelligence, but did you inspect each plug wire? If they get too close to headers they can get burnt. Happened to me. Caused missing. I didn't notice by looking at them since the burnt part was on the bottom of the wire. I had to physically inspect 100% of the wires to find it. Just a thought...
Old Jun 14, 2006 | 03:43 PM
Ed Blue 03's Avatar
Ed Blue 03
Yep, look at your engine in the dark while it's running. You may have a spark plug wire arcing. Once had this problem, took me forever to figure it out. Good luck.
Old Jun 14, 2006 | 06:15 PM
75SHARK's Avatar
75SHARK
I've inspected the wires as best I could, but I do need to pull them out individually and look at them. I had the car running in my garage in the dark, but no sparks seen. That was one of the first things I checked because I my '73 was doing it.
Old Jun 14, 2006 | 09:37 PM
terry82's Avatar
terry82
i would look at each plug .
To Looking For Help Diagnosing Engine Miss
