-6 an hose
Old Apr 30, 2006 | 05:13 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default -6 an hose
How big is -6 an hoses? How big of a line would I need to feed 2 of these -6 an hoses?
Old Apr 30, 2006 | 05:19 PM
kdcollins's Avatar
kdcollins
I dont know what size line would be required to feed 2 -6 AN's but a -6 AN is 3/8".
Old Apr 30, 2006 | 05:22 PM
Guru_4_hire
Cruise-In V Veteran
thanx
Old Apr 30, 2006 | 07:29 PM
70 LS1's Avatar
70 LS1
the -6 means 6/16" or 3/8". That means -8 would be 8/16" or 1/2"
Old Apr 30, 2006 | 08:08 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Find inner arear of the 6 an line and double that then find the radius and that should be how big you need it to be.
Old Apr 30, 2006 | 08:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Apr 30, 2006 | 08:19 PM
Guru_4_hire
Cruise-In V Veteran
well, I have this obtuse 12mm x 1.25mm inlet into my dellorto carbs
So I can find these -6 adapters but I have 2 of those. A -8 an line comes out of the fuel pump.
So the varius fittings arent cheap. I fail to see why a 1" fiting costs 30 bucks, its robbery I tell you.
Old Apr 30, 2006 | 10:12 PM
pef427's Avatar
pef427
I have a -10 to the regulator and 2 -6's coming out of the reg. feeding the carb with a -8 return line to the tank.
Old May 1, 2006 | 06:43 AM
Guru_4_hire
Cruise-In V Veteran
return line?
Old May 2, 2006 | 09:36 AM
pef427's Avatar
pef427
return line?
Yes, I have an Aeromtive 1000 and it calls for a return line from the Aeromotive regulator.
Old May 2, 2006 | 04:52 PM
Twin_Turbo's Avatar
Twin_Turbo
a -6 line has an equivalent ID as the ID of a 6/16 OD hard line!!. The measurement system comes from using a standardized size for flare nuts on hard lines w/ 37 degree sealing surfaces, the nut sizes are what determines the AN size. The hose adapters that you use are measured in that system. The ID of a -6 line is around 5/16th
Old May 2, 2006 | 08:14 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if you see a -6 or -8 remember that it is the ID size of the hose in 16ths of an inch.
Old May 2, 2006 | 08:19 PM
Guru_4_hire
Cruise-In V Veteran
thanks guys
Old May 2, 2006 | 08:58 PM
redvetracr's Avatar
redvetracr
actually a -6 Aeroquip hose has an ID of .34 and -8 has an ID of .44
...redvetracr
To -6 an hose
