Pedal conversion
Old May 1, 2006 | 12:01 AM
redson's Avatar
redson
Default Pedal conversion
After cutting down my brake pedal to size,for more footroom,I sent the requested drawings,measurements,& digital pics of the accelerator & brake pedals in to Ultimate Pedals ( www.ultimatepedals.com )Meanwhile,I used sandpaper,rust encapsulator,& then semi-gloss black paint on the metal surfaces of my pedals.After recieving my new aluminum pedals,I followed the procedures outlined by the manufacturer...I used an automatic center punch to mark the spot to drill,then I started with a 1/8" drill bit,then finished with a 9/32" bit to complete the mounting holes for the screws,washers,nuts and studs.After inventing a new yoga pose (I'm 6'3"),I managed to get all the nuts started in back of the brake pedal,to mount it.The gas pedal in my 79 is plastic,which required only the stainless screws for attachment
Old May 1, 2006 | 07:01 AM
Michaeljh2000's Avatar
Michaeljh2000
Lookin' good.
Old May 1, 2006 | 08:41 AM
norvalwilhelm's Avatar
norvalwilhelm
Looks good but a 9/16 drill bit??? That is over 1/2 inch. What were to drilling that big a hole for??
Old May 1, 2006 | 09:54 AM
Red_Shift's Avatar
Red_Shift
Maybe some new pedals are now on my Christmas list.
What did you use the 9/16" drill bit for?
Old May 2, 2006 | 03:14 PM
redson's Avatar
redson
oops! You will require the following tools, which can be obtained at any local hardware store:
#2 Philips screw driver
Open end-Box wrench 7/16"
Drill bits 1/8" and 9/32"
Electric drill
Automatic center punch
Pencil
Degreasing spray
2" wide Masking tape
To Pedal conversion
