Question for Lars
Old May 2, 2006 | 09:15 AM
jmh63's Avatar
jmh63
Default Question for Lars
Got the Q/Jet tore down for a rebuild and found that someone has taken a hacksaw to the center two brass tubes on the carb top (see picture). Any idea on what in the heck they were trying to do by making these tubes shorter and is it worth trying to rebuild this carb for street use on my '74?
Thanks...Jack
Old May 2, 2006 | 11:59 AM
SIXFOOTER's Avatar
SIXFOOTER
The center ones that look like the ones that are cut off (can't tell about the outside tubes) are the Secondary Main Well Air Bleed Tubes. I thnk they allow air to bleed back into the secondary well to allow fuel to flow in the Secondary Fuel Feed Tubes. Someone aparently thought cutting them would allow more air, therfore more fuel to flow.
Don't know how it worked out, or if it matters.
Are the Fuel Feed Tubes cut too?
Old May 2, 2006 | 12:07 PM
jmh63's Avatar
jmh63
Only the center tubes are cut, have never ran this carb so have no idea on what effect the cut tubes will have...thanks
Old May 2, 2006 | 12:37 PM
BigBlockk's Avatar
BigBlockk
These tubes had crimped ends and calibrated air bleed holes originally. With that removed I would think the secondary metering would be leaner than is desirable. I have replaced the larger secondary fuel tip in pickup tubes but never the smaller air bleeds. You may need a new carburetor top.
BigBlockk
Later.....
Old May 2, 2006 | 12:40 PM
lars's Avatar
lars
Those are fuel emulsion tubes, and you need them. Get a junk Q-Jet and yank the tubes out of the airhorn and install them into your carb.
Lars
Old May 2, 2006 | 01:33 PM
jmh63's Avatar
jmh63
All, thanks for the input...looks like I need to find some replacement tubes. Are they all the same and are there any tricks to replacing them? Thanks Jack
Old May 2, 2006 | 01:47 PM
SIXFOOTER's Avatar
SIXFOOTER
Lars
Hey Lars;
Is that the same as air bleed? or was I looking at the wrong pic in the book? And what is the function of the tubes?
Dan
Old May 2, 2006 | 03:21 PM
BigBlockk's Avatar
BigBlockk
Originally Posted by SIXFOOTER
Hey Lars;
Dan
These tubes fit down into small round wells called emulsion tubes or emulsion wells. Air flows down through these tubes and bubbles out into fuel flowing from the secondary metering jets. This air acts like a break on the fuel flow. Without it, the secondary fuel mixture would get richer and richer as as the secondary air valve opens. The air bleed tubes meter a little air into the fuel flow to lean it out some. Yours, having been cut off, will allow too much air into these wells and will screw up the mixture calibration. They are also a siphon break.
BigBlockk
Later.....
Old May 2, 2006 | 06:48 PM
SIXFOOTER's Avatar
SIXFOOTER
okie, well I was pretty close then, thanks
Old May 4, 2006 | 07:43 AM
68435roadster
Guest
Posts: n/a
Jack,
I'll see if I have these tubes on an old carb. Maybe Lars has them? G.
Old May 4, 2006 | 07:59 AM
jmh63's Avatar
jmh63
Sounds good George, let me know. Thanks Jack
Old May 4, 2006 | 09:41 AM
lars's Avatar
lars
I have a bunch of them if you need them. Just lemme' know...
Lars
Old May 4, 2006 | 09:55 AM
a1sensei's Avatar
a1sensei
The ideal standing height for these tubes is exactly one inch. Often they are not imbedded deeply enough into the air horn and stick too far into the emulsion wells, impeding secondary fuel flow. That is very common and is usually not any real problem except for serious performance use. The previous owner probably heard that and decided cutting them off was the right solution (a little knowledge is a dangerous thing!). Actually, to get the ideal standing height, you need to fabricate a special tool by drilling and counter sinking a peice of aluminum rod. Otherwise, just tap them in carefully so as not to damage the ends, and live with them a little too far out. You'll probably never know the difference. God bless, Sensei
Old May 4, 2006 | 10:03 AM
jmh63's Avatar
jmh63
Thanks Lars will take you up on the offer...sending email
Sensei thanks for the input
To Question for Lars
