Windshield wiper problems
Old May 3, 2006 | 03:16 PM
wheelsup's Avatar
wheelsup
Default Windshield wiper problems
Could anyone show me a wiring diagram of the wiper switch to the wiper motor. Is there a relay and where is it located?
Old May 3, 2006 | 03:40 PM
dboncio99's Avatar
dboncio99
Depends on the year, but if you have intermittent wiper option there is a relay in the back under the passenger side storage compartment. You can try to find another one (But they are discontinued and there is not an after-market one yet) or just go to LectricLimited and get the jumper plug to bypass the relay. Everything works then except the delay mode. I think there is also a post in here somewhere, if you search, for a do-it-yourself bypass wiring diagram. Good Luck!
Old May 3, 2006 | 03:48 PM
wheelsup's Avatar
wheelsup
Opps, the year is 1969. The wiper now run continuously
Old May 4, 2006 | 09:06 AM
wheelsup's Avatar
wheelsup
I did a seach for the thread on bypassing the relay, but no luck. Has anyone used this wiring manual currently on Ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old May 4, 2006 | 09:20 AM
sly vette's Avatar
sly vette
Remove the wires from the wiper motor and the motor may reset itself. Plug them back and see what happens. You may have a bad motor.
Later,
Sly
Old May 4, 2006 | 09:26 AM
wheelsup's Avatar
wheelsup
Sly, without a wiring diagram I'm not sure that this thing is wired correctly. The pump has been replaced. Someone has played with the pump wiring in the past.
Owner: 1967 427 Coupe
1969 427 Coupe
1991 Big SBC...see Sig
Old May 4, 2006 | 01:41 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
This guy's drawings seem to have a pretty good rep.
http://www.vetteheads.com/forums/showthread.php?t=4838
http://www.vetteheads.com/forums/showthread.php?t=5458
http://forums.corvetteforum.com/show...3&forum_id=119
http://forums.corvetteforum.com/show...194&forum_id=3
http://www.corvetteactioncenter.com/...ad.php?t=81199
Don
Old May 4, 2006 | 01:51 PM
iNdigo's Avatar
iNdigo
Yeah, I bought this same manual from the same guy about four years ago. it's just a photocopied stack of papers from some GM service manual that's out of print.
I have it at home, but i've drawn all over it because I was customizing the circuit to get rid of the washer portion.
Probably worth the $15 if you want to know everything there is to know about the wiper setup on your '69.
Or I could fax it to you if you ask me nicely.
Old May 4, 2006 | 02:47 PM
wheelsup's Avatar
wheelsup
iNdigo, I would appreciate a fax. Please I sent you a PM with my Fax number.
Thanks...Phil
To Windshield wiper problems
