Shorted Sidepipes and Mounting tab Drawings
Old May 3, 2006 | 05:00 PM
84rzv500r's Avatar
84rzv500r
Default Shorted Sidepipes and Mounting tab Drawings
It took a while to get the uploads approved...
I took a minute to draw up the sidepipes that I am building to clear the 325's on the rear and quiet down the beast a bit.
I chose the 25 inch muffler as I have 20 inches if 3.5 inch baffle in my current pipes. These are a full 4" id. Hopefully more attenuation and better flow.
I drew up the dimensions of the tabs in case anyone wanted to copy them for use in a project. I was gonna CNC plasma cut them from 1/8 sheet. But I had some 1.5 x 0.125 flat stock so I will do it on the CNC Mill. Cut 4 blanks, zero the mill, hit Cycle Start and get a beer. I'll cut all 4 at once.
Old May 6, 2006 | 09:11 PM
84rzv500r's Avatar
84rzv500r
Welded the sidepipes together this afternoon and installed them on the car. They are a direct replacment for the Hooker sidepipes. I am very pleased, the sound is there but it is very mellow until about 3500. The mufflers are 4 inch ID and 5 inch OD. I can now carry on a conversation with the passenger comfortably with the side windows down at any speed up to about 80 mph.
I ended them flush with the edge of the fender lip. No more tire clearance issues.
I'll send them to jet hot over the winter.
I was headed for a ticket and a hearing aid before.
I'll post pics and the as built drawing later...
Old May 7, 2006 | 11:26 AM
1Z87L8's Avatar
1Z87L8
nice work, looking forward to the photos.
Old May 7, 2006 | 08:24 PM
84rzv500r's Avatar
84rzv500r
Default Custom Sidepipe muffler Pics
Snapped some shots today...
Old May 7, 2006 | 08:27 PM
1Z87L8's Avatar
1Z87L8
they look great now all you need is a set of
deans shields and you will be in business
Old May 7, 2006 | 08:57 PM
84rzv500r's Avatar
84rzv500r
I'll bet he dosent make them in 5"
BUT I know this guy with a CNC Plasma cutter who could make his own
I'm gonna get them jet hot coated black this winter.
To Shorted Sidepipes and Mounting tab Drawings
