Brake proportioning valve
Old May 4, 2006 | 07:50 AM
Baytraveler's Avatar
Baytraveler
Default Brake proportioning valve
Recently I braked pretty hard. My brake light on the dash came on soon afterword. I thought it might be just that I bumped my parking brake lever as I have done that in the past. However, the light stayed on after I checked the PB lever. The brakes seem to work fine and I arrived to my destination. After restarting the car some time later, the brake light was off. Again I needed to brake fairly hard and the Brake light came on. From my research it seems like it likely that my brake proportioning valve has gone bad. Does this seem correct? There is no fluid loss in the master cyliner.
Additionally, if it needs to be replaced, any issues or pitfalls when replacing this part that I should be aware of?
Thanks for any advice.
Old May 4, 2006 | 07:58 AM
pws69's Avatar
pws69
It depends on what year you have as to whether it is a proportioning valve or a distribution block.
In any event, if the light comes on, then there is an imbalance between the front and rear systems. This can be caused by low fluid, leaks, air in the system, etc... How old are your brake pads? When did you last bleed the system?
Old May 4, 2006 | 09:23 AM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like the proportioning valve did its job (if you have one) It is supposed to shift over (and turn on the light) in the event of a leak in the brake system that causes low pressure in one leg or the other. If the light went off the valve shifted back to normal, this indicates air in one leg. Bleed thuroghly on all 4 calipers and you should be good to go.
Old May 4, 2006 | 01:38 PM
norvalwilhelm's Avatar
norvalwilhelm
I don't believe we have a proportioning valve. Like other have already said either the front or the back is leaking and you have an imbalance in line pressure causing the pressure switch to short to one side turning on the warning light.
If the car stops well I would suspect the back as the problem. If the brakes feel mushy I would look at the front.
Old May 4, 2006 | 02:21 PM
iNdigo's Avatar
iNdigo
yeah, it's misleading terminology... the "proportioning valve" doesn't exactly live up to it's name. sounds like yours is working fine if it returned to neutral.
Old May 4, 2006 | 03:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SIXFOOTER
.....Bleed...all 4 calipers and you should be good to go.
Old May 5, 2006 | 08:40 AM
Baytraveler
ok, I'll bleed the system and see what happens. Thanks for the advice.
Old May 5, 2006 | 10:31 AM
Duke94's Avatar
Duke94
If the light stays on, pull the connector off the switch on the proportioning valve. If the light goes out, then either you have air in the system or the switch is bad. If it stays on, then it's the e-brake switch or a short to ground in the wiring.
Old May 5, 2006 | 10:33 AM
crazywelder's Avatar
crazywelder
with the diagnosis, but it's a distribution block and switch only.
Old May 5, 2006 | 11:16 AM
Duke94's Avatar
Duke94
All depends on what year he has. 74' and before were just a distribution block and after had the proportioning valve as well. Easy way to tell: If the valve is mounted on a bracket on TOP of the frame rail, it's a distribution block. If it's mounted with 2 bolts on the SIDE of the frame rail, it's a proportioning valve.
To Brake proportioning valve
