speedometer back lighting
Old May 3, 2006 | 11:56 AM
Hef's Avatar
Hef
Default speedometer back lighting
My speedometer back lighting is out, the Tach lighting works fine and other gauges as well. Is this a simple bulb change?
Thanks,
Hef
Old May 3, 2006 | 12:06 PM
SpcCox's Avatar
SpcCox
yea either that or the bulbs just came out, that was the problem on mine....that would be the most logical solution.
Old May 3, 2006 | 02:47 PM
mdj21's Avatar
mdj21
on my 73, some of the bulbs had corroded. i cleaned up the sockets and the end of the bulbs and most of them started working fine. (did have to replace a dead one or two.)
NAPA should have any of the dash bulbs you need.
Old May 3, 2006 | 03:31 PM
Todbo's Avatar
Todbo
bulbs just push in , if you've done anything under the dash , might have pulled a bulb out
Old May 3, 2006 | 05:38 PM
Beater's Avatar
Beater
speaking for a '79 it is fairly easy. The toughest part is pulling the cluster out from behind the wheel and disconnecting the speedo drive cable. The bulbs are in a in twist and lock sockets. All that usualy need to be replaced is the bulb.
What year is yours? The clusters changed with time.
Old May 3, 2006 | 10:33 PM
savage118's Avatar
savage118
73's have bulb plugs that break easily, so be carefull if you have the plastic, and metal claw type. Once the metal claw pull out they are junk, and the bulb won't stay in. I replaced many of them when I changed all the dash bulbs. Kind of a pain.
Old May 4, 2006 | 11:22 AM
Hef's Avatar
Hef
Default removal
Forgot to mention that its a 79.
I have never worked on the dash, or under it, so this is new territory for me. Any suggestions on how to go about getting at the bulb?
Hef
Old May 4, 2006 | 11:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Hef
....Any suggestions on how to go about getting at the bulb?...
Long way around, but most comfortable is to loosen the cluster and pull it forward enough to get your hand behind it.
Quick way is to arm yourself with a flashlight and lay on your back to peer up behind the cluster. It will be a tight fit. Lots of stuff behind the cluster.
Old May 4, 2006 | 04:34 PM
Beater's Avatar
Beater
Hef
Mine is out of the car so I can tell you it isn't that bad.
There are 2 screws on the sides that have to come out.
a total of 6 along the top (3 for the lense, 3 for the cluster)
You can see the heads of all of them.
get the side ones out first, then undo the top 6 that hold in the lense (these are pretty tiny) and cluster. Reach inder the dash and feel for the back of the speedo. There will be a metal band that goes around the drive cable that you will have to undo. Push the tab at the bottom of the band forward (tward the driver seat) with your thumb and wiggle the cable off.
The cluster will now be free except for the wiring harness. Pull it straight tward you. It helps if you take the lense off now, it is the only way you'll be able to completely remove the cluster. Once you have it pulled out enough, reach behind the cluster and squeeze the tabs on the cluster and pull it out. If any of the contacts are break loose from the circuit board (plastic sheet) glue them back into place with supper glue. Then start the endless process of changing bulbs followed by "hey I should re-paint this," and "Should this be rebuilt?"
Old May 5, 2006 | 11:29 AM
Hef's Avatar
Hef
Default cluster
Thanks I will give that a try this weekend!
Hef
To speedometer back lighting
