Brake Rotor Dragging
Old May 4, 2006 | 08:32 AM
11Jake's Avatar
11Jake
Default Brake Rotor Dragging
I recently rebuilt the entire brake system on my 80 Vette. New rotors rebuilt the calipers, new brake lines, new master cylinder and new pads. After I put everything back together it seemed the pads were dragging on the rotors a little too much. I understand that after new pads and rotors it will drag a little, but it seemed excessive. Is this normal?
Old May 4, 2006 | 08:37 AM
sly vette's Avatar
sly vette
A little drag is normal. However the car should still roll easily.
Later,
Sly,
Old May 4, 2006 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "excessive." Corvette pads are in contact with the rotors all the time. Wheels/rotors should spin by hand and you should be able to hear and feel a little drag.
To Brake Rotor Dragging
