question for hurst comp. plus users
Old May 5, 2006 | 10:49 PM
bondoboy's Avatar
bondoboy
Default question for hurst comp. plus users
Will the stock upper and lower shifter boots work with the hurst shifter? If not, does someone make some that will? Thanks a lot.
Old May 5, 2006 | 10:51 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I'm using the stock boots with mine, no troubles...
Old May 5, 2006 | 10:56 PM
Burgundy 69's Avatar
Burgundy 69
No problems for me.
Old May 5, 2006 | 11:26 PM
bondoboy's Avatar
bondoboy
Thanks guys. I was concerned because the stock shifter is round and the hurst is rectangle shaped. It didn't look like it was going to fit, but I guess it will.
Old May 6, 2006 | 12:42 AM
Solid LT1's Avatar
Solid LT1
Get the bolt on "stock" style shift handle and the stock boots will work great, and the interior will look stock. You can find them in Corvette Central's catalog, I use the 63-7 "Mid-Year" stick (about 2-3" shorter than the C3 shift handle) for a shorter throw on my 72 LT-1.
To question for hurst comp. plus users
