A big factor in this is; some people dont chase all the threads and clean out the holes before re-assembly.
I've seen many oil leaks, and I've seen dry intakes.
Torqing 101---always start with true, dry, clean threads for torque accuracy.
Gotta have a clean hole so your bolt dont bottom out.
If the bolt bottoms out before the part is actually torqued correctly; its a recipe for a possible leak.
Do you use a thin film of sealant around the waterjacket on the gasket or do you leave the gasket totally dry?
I did it and now it takes water... Used Fel-Pro Printoseal gasket.
