Turbo 400 question
Old May 6, 2006 | 10:22 AM
Sweet L82's Avatar
Sweet L82
Default Turbo 400 question
I notice that when I put my 76 in park on a slight incline the car moves/rolls back and kind of shudders as it does so. After I stop the car with the brake, the trans will hold it. The car shifts and runs perfect with no strange noises- the trans fluid appears like new (pink - no burnt smell). The pan is wet from fluid and occasionally I will have a good size puddle of trans fluid after sitting overnight. Is this sign of a major problem? What can I check?
Old May 6, 2006 | 12:32 PM
eileenthevette's Avatar
eileenthevette
How often do you drive the car? Does this occur just after start up?
As a rule, I never park a car on an incline using the tranny to hold the car. Mainly because I hate the KLUNK of engaging the transmission when I put it into gear. I always hold the brakes, put it in neutral, engage the parking brake, then put it in park. Emergency brakes are cheaper than transmissions.
Old May 6, 2006 | 03:13 PM
chris75stingray's Avatar
chris75stingray
that sounds normal .when you put the trans in park, the drive shaft will still turn alittle untill it locks in place
Old May 6, 2006 | 03:49 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
yup
mine does it all the time.. havent blown it up (suprisingly)
Old May 6, 2006 | 06:07 PM
7T1vette's Avatar
7T1vette
Default Tranny Leakage
You mentioned that it "gets wet". Where? At the gasket line? At the vacuum modulator? Most likely your problem is a gasket/seal leak. Replace the gasket with a GOOD one (rubber/synthetic impregnated). If your vacuum modulator diaphragm is ruptured [does it shift particularly hard?], that could be the source of leakage. The only other areas of leakage are the oil filler tube seal, the cooler lines, or any pipe plugs on the outside of the case. If you check your level regularly and it doesn't appear to be losing much oil, it is probably just a "drip" problem.
Old May 9, 2006 | 10:01 PM
Sweet L82's Avatar
Sweet L82
Thanks for the replies!! I will replace the pan gasket this weekend.
To Turbo 400 question
