Added power...
Old May 6, 2006 | 12:01 PM
jerrylee's Avatar
jerrylee
Default Added power...
What's the diff. between using a nos system vs. a turbo or super charger when looking 4 added power....thanx///
Old May 6, 2006 | 12:14 PM
Little Mouse's Avatar
Little Mouse
I will never run nos but thats just me its a very good cost per
horse power way to go. Turbo system would be great lots of
dollars. you need tough pistons for both. Even with a smaller 100hp
system nos don't let anyone tell you can get by with cast or hyper
pistons if you want to do the job right. not sure what you are wanting
in the way of differences.
Old May 6, 2006 | 12:51 PM
The3's Avatar
The3
NOS gets tricky if your not set up for it. It's the cheapest way to go though. You could also just use a 25-50 Hp shot and you should be fine. Depends on the condition of your engine.
Turbo setup is good but expensive.
Superchargers are a good way because they add a lot of power, depends on boost, and can be easilly installed. You can buy a SC kit for about $3500. I think this includes a intercooler. Superchargers are a little tempermental though when it comes to the weather. They don't like heat.
How much money do you got?
Old May 7, 2006 | 09:16 AM
jerrylee's Avatar
jerrylee
This is a project 4 down the road.....n money is a little low because I'm in the final stages of an engine rebuild........I should have around 425 on the horse when finished and I would luv 2 pump her up ove 500 so I can keep up with those new vettes......by the way I have the new speed pro forged pistons in there will those b ok....thanx....
To Added power...
