Fuel pump question
Old May 6, 2006 | 06:23 PM
Oldguard 7's Avatar
Oldguard 7
Default Fuel pump question
I have purchased a new fuel pump and was wondering is the brass fitting necessary? Also is it necessary to replace the feul pump rod?
Old May 6, 2006 | 07:21 PM
shafrs3's Avatar
shafrs3
No, neither is necessary.
Old May 7, 2006 | 01:29 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Called inverse flare fittings.
Well that brass fitt'n should mate to the tubing flare for sealing.
A good specaily hardware store will carry inverse flare fittings if u want to make changes. I recall flex line to intlet and flared 3/8" tubing on outlet of pump.
I installed my Carter street pmp with 45* fittings only - no 90*. Aligned the pmp housing so fittings see only smooth transistions to the tubing - reduced restrictions. Removed my "S" bent/formed inlet flex line so inlet flex makes gradual bend accross top of pmp and down. I see 6psi-9psi right at the carb now without a inline regulator.
U can set it up for your application.
cardo0
To Fuel pump question
