Voltage from Dist Bat to ground??
Old May 8, 2006 | 09:46 PM
BIGJIM13's Avatar
BIGJIM13
Default Voltage from Dist Bat to ground??
HI
on a HEI - 75-76 dist, what type of volt meter reading should I get between the dist bat wire and ground?
Old May 8, 2006 | 10:24 PM
SIXFOOTER's Avatar
SIXFOOTER
that would be 12 volts, it comes from the ignition switch
Old May 9, 2006 | 09:10 AM
BIGJIM13's Avatar
BIGJIM13
Thanks - where does the other end of the wire hook up at ?
One end goes to the distributor side marked Batt - where does the other end connect?
Old May 10, 2006 | 09:29 AM
BIGJIM13's Avatar
BIGJIM13
Guys
When I test the voltage between the wire that goes to the BAT on the distributor and ground, I get a spark instead of a voltage, is this an indication that the guy before me had something wired wrong?
Old May 10, 2006 | 10:44 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by BIGJIM13
Guys
voltage gets measured in parallel almost sounds like you are doing it in series....the other end of that ulitmately goes to the ignition switch.
Old May 10, 2006 | 11:33 AM
BIGJIM13's Avatar
BIGJIM13
what the best way to check it then?
Old May 10, 2006 | 11:48 AM
SIXFOOTER's Avatar
SIXFOOTER
Hey Jim;
connect the black lead on the volt meter to some ground point on the engine. Connect the red lead to the BATT wire at the distributor. Key on = 12 volts (or whatever is in the battery) Key off = Zero (close to it)
Do the same test with the wire disconnected, then connected. you should get the same results.
Old May 10, 2006 | 01:11 PM
BIGJIM13's Avatar
BIGJIM13
HI
well the issue I have is when I put my red lead on the connector wire that goes to Bat (unconnected) and the black on ground - I get a spark instead of a reading
Old May 10, 2006 | 02:49 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like a flakey volt meter, it should not spark
Old May 10, 2006 | 05:13 PM
greg454's Avatar
greg454
sounds like your using your meter in the amperage setting and not the voltage setting. Make sure your leads are plugged into your meter correctly, the red wire usually plugs into different holes for the volt and amp settings.
Old May 10, 2006 | 05:41 PM
BIGJIM13's Avatar
BIGJIM13
Thanks - been doing things like this for a while..meter is set correctly..thats why it does not make any sense..
Thanks for the comments!
Old May 10, 2006 | 05:43 PM
bobs77vet's Avatar
bobs77vet
HI
this will always happen thats not how a volt meter is used.....you need the circuit to be energized and connected to a ground and then take the reading.....try making a jumper off the connection and hook it up normally, then use the jumper to measure the voltage like you are doing and it should work fine.....a test light will work they way you are doing it but a voltage meter will not.....an amp meter will however measure all the current that is flowing to ground...
Old May 11, 2006 | 09:30 AM
BIGJIM13's Avatar
BIGJIM13
I located a short - that was the problem
have both volt meter and amp meter - was using the correct one, most seem to only know the term volt meter!
Thanks for the replies!
Old May 11, 2006 | 11:10 AM
mandm1200's Avatar
mandm1200
You check voltage in parallel with the circuit. Hold the leads across a hot wire and the other to ground. A voltmeter is actually an amp meter. When used as a voltmeter it has very high resistance. When used as an amp meter it is connected in series and is low resistence. That's the reason for plugging the red lead into a different socket on the meter.
If you are getting a spark, either the meter is bad or more than likely not plugged into the right socket.
You still have me confused. If you had a short going to the battery terminal at the distributor, how were you getting it to spark?
To Voltage from Dist Bat to ground??
