Cross-Threaded Trans Cooling Line in Radiator...
Old May 10, 2006 | 07:53 AM
TedH's Avatar
TedH
Default Cross-Threaded Trans Cooling Line in Radiator...
Well, they don't call me 'torque wrench Ted' for nothing...
I managed to incorrectly thread the lower trans cooling line into my rebuilt radiator... So much for the $108 I spent for the tank repair. Now I gotta decide if it is worth pulling the radiator and having it repaired AGAIN or considering a trans cooler. My concern is where to mount a trans cooler? I'm not crazy about attaching it through the radiator but that may be the only practical option. Suggestions?
Old May 10, 2006 | 10:31 AM
TedH's Avatar
TedH
I think I'll suffer the embarrassment of returning the radiator for a 2nd repair... pulling it this evening. Next time, I'll do what I shoud've done and put a light film of grease on the line threads and tighten it by hand; it is a bit of trouble to get at that line with my left hand heaving scratched and bruised from tight clearance betw the fan shroud & radiator...
At over $10 gallon, I'll be recovering the fresh radiator fluid for a 2nd, more careful go at it later this week. I was really hoping to get the L48 out but I'll have to be patient :o
Old May 10, 2006 | 10:45 AM
gkull's Avatar
gkull
Ted, Back when I used the side tank for auto tranny cooling. I had the 3/8ths flare tubes with nut screwed into the radiator. They were cut short so I could install them with teflon tape while the radiator was out.
It's been a long time but the top was just a short straight piece and the lower was a 90 deg. short piece. Then I could install the radiator and then just slib the tranny hoses over the pipe end with a screw down clamps.
Old May 10, 2006 | 10:09 PM
Glassbowtie77's Avatar
Glassbowtie77
Actually, I believe the top pipe is the one with the 90 degree bend in it, and the bottom is the straight one.
Old May 10, 2006 | 11:01 PM
Restorod '79's Avatar
Restorod '79
I just installed a small tranny cooler right in front of the radiator, centered and at the bottom to stay out of the way of the hood. The REASON I did this was that after numerous repairs and replacements around the front end, the radiator fittings and hoses from the tranny HAD TO MOVE ! I couldn't get a tool OR my fingers to these things, and if I ever wanted to pull the radiator again, I figured I'd damage the fittings in anger! The small cooler (Summit # PRM-1005) will install easily anywhere you want to put it. It's light, has brackets built in, and comes with fittings. That's one little hassle I'm glad to have behind me!
Old May 10, 2006 | 11:16 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have the same set up as gkull.....flared tubes that the hose slip over....the nuts are fastened before the radiator slips in.....if i were to mount a trans cooler i would do it horizionatally up by the vaccum tube with home made brackets
Old May 11, 2006 | 06:17 AM
rpoL98's Avatar
rpoL98
I mounted an Earl's trans cooler attached vertically (slight forward angle) to the vacuum reservoir in front of the radiator (the big metal tube/pipe running crossways, it's a '78). Used the Earl's mounting brackets attached with fabricated aluminum angle piece and hose-clamps. been attached for years and couple ten-thousand miles and still real solid. easily clears hood opening. of course, I'm using -6 braided hose and AN-flare adapters and AN fittings.
Old May 11, 2006 | 09:25 AM
TedH's Avatar
TedH
I'd appreciate any pictures you have of this setup. I'd rather leave the radiator in the car and go with a cooler mounted horizontally forward close to the vacuum canister ... Save me the aggravation and mess of removal/reinstallation and maybe provide better cooling for my 700R4 in the process. Am wondering if it is possible to get high pressure hoses with female connections so that I could screw the two pipes to the lines that run forward to the new cooler. At minimum, I'll go with high pressure (rubber hoses off the two lines. I recall now that both trans lines @ the radiator have lengths of hose between them and the main trans lines so I don't know why I didn't leave the lines in the radiator and just pull the hoses off... I should have...
Old May 11, 2006 | 11:33 AM
TedH's Avatar
TedH
Just ordered. Thanks for the tip!
P.S. As I wait for the cooler to arrive, please advise if you can send a pic or two of your installation.
To Cross-Threaded Trans Cooling Line in Radiator...
