82 experts
Old May 8, 2006 | 09:58 PM
rastadr's Avatar
rastadr
Default 82 experts
hey folks. the fuel pump wouldn't shut off until i pulled the fuse. where is the fuel pump relay? and does it make sense that its the culprit? why is there a jumper wire between the right terminal of that fuse and the right terminal of the breakdr assembly below it? is this a bubba thing?
Old May 9, 2006 | 05:56 AM
GL82TPI's Avatar
GL82TPI
The fuel pump relay is inside the compartment behind the battery. You will have to remove the storage compartment behind the seats to see it. There might be more than one relay in there but I believe the fuel pump relay has a tan and white wire going to it. I'm not sure if it is the problem or not, but I suppose if it were to fail in the on position it would let the pump continue to run. You will find you ECM there too.
