i am restoring 1982 vette crossfire. had the engine completely serviced.plugs, wires,rotor,throtlebodys and etc. i can not get the idle below 1200. adjusted th. bod. all the way slow. any advice?
check for vacum leaks , and or your IAC motors are bad or sticking due to corbon build up on the pintle. Mine does this only sometimes but very rare , so JGVette might have good sugestion.
the computer controls the idle .you have a vac leak
Yes true ! but if the IAC's are inop or the pintle's (on the iac's) have corbon build up causing to stick to open or closed the ECM only does so much so if there is a vacum leak (you would hear it) or there is a sensor malf............................
Most 82s with a high idle are associated to a vacuum leak.
You could also try to replace your ECM Coolent Temp Sensor located by your thermostat housing. This can go bad, tricking the ECM to believe it is cold and setting you up in high idle.
You could also try to set yourself up with the Win ALDL program, an old laptop PC, and an RS-232 to ALDL converter cable to monitor your ECM operation/sensors real time to see if there is anything going on.
