Which spark plug for #186 casting heads?
Old May 9, 2006 | 10:49 PM
Uesu's Avatar
Uesu
One gear at a time
Veteran: Marine Corps
CI 8-9-10 Veteran
St. Jude Donor '07-'08-'09
Default Which spark plug for #186 casting heads?
Looking for the correct spark plug for a set of 1970 #186 heads. These heads have the 64CC chamber. I would like a plug in the 45* heat range.
Would the correct plug take a 5/8" socket or a 13/16 socket?
Recommendations would be appreciated. TIA Wes
Old May 9, 2006 | 11:02 PM
dennis's Avatar
dennis
Well on the 70 Lt1 that head uses a R-43. On the base 350 with that head.... R-45. My 70 L-46 same head calls for R44.
Having used all 3, I now run the r-45's. Burn best and easiest to find.
Old May 9, 2006 | 11:06 PM
Uesu's Avatar
Uesu
One gear at a time
CI 8-9-10 Veteran
Dennis, thanks for the reply. Would that plug happen to take a 5/8 or 13/16 socket?
Old May 9, 2006 | 11:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
its the small socket size
Old May 9, 2006 | 11:11 PM
Uesu's Avatar
Uesu
One gear at a time
CI 8-9-10 Veteran
Thank you bobs77vet.
Old May 10, 2006 | 02:10 AM
Uesu's Avatar
Uesu
One gear at a time
CI 8-9-10 Veteran
I just went and tried to install a set of the smaller plugs in one of the heads, and they did not want to seat right. So, I got under the car so I could see the spark plug seat. The seat was flat like a 461 head would have. I pulled a valve cover, and the date looked like C 9 0.
Any thoughts on this?
Old May 10, 2006 | 07:07 AM
dennis's Avatar
dennis
its the large plug
Old May 10, 2006 | 08:26 AM
bobs77vet's Avatar
bobs77vet
you could have a stripped threads.....these are old heads and probably have had a lot of plugs pit in them over the years....these are the double hump fuelie heads right? i didn't have any problems seating my spark plugs.
Old May 10, 2006 | 10:45 AM
Uesu's Avatar
Uesu
One gear at a time
CI 8-9-10 Veteran
bobs77vette, the 186 head has two small humps and accessory bolt holes, it is later than the "feulie" heads. The area where the plug goes looks like a large, flat circle. I didn't crank down on the plugs, and the threads look fine, so I don't think I damaged them.
I went and pulled a plug on my truck this morning; the truck uses the smaller 5/8 socket plugs. The area under the plug looked different, it was tapered where as, the #186 head was flat.
Dennis, I'm going to pick up a set of the larger plugs on my way home from work tonight. It's been a while since I ran these heads, and for some reason, I couldn't remember what plugs I used to run in them.
Thanks again for all the help. Wes
Old May 10, 2006 | 11:26 AM
gkull's Avatar
gkull
I used the small taper bosche P+4 in my 186 casting heads for years with different cams and intakes.
Old May 10, 2006 | 01:40 PM
dennis's Avatar
dennis
That 70 head takes the large,(non tapered), plug.... period.
Old May 10, 2006 | 04:49 PM
bobs77vet's Avatar
bobs77vet
sounds like there are different sizes ...try dennis's answer if my didn't work....
edit just reread your initial post and i believe those are the heads i have with the small tapered plugs, although i don't know what car they came off of originally? not sure why the difference but sounds like Dennis may have you answer
To Which spark plug for #186 casting heads?
