Reverse
Old May 10, 2006 | 03:47 PM
nc98z's Avatar
nc98z
5th Gear
Default Reverse
I have a 81 vette with the 4 speed in it. I am having trouble putting the car in reverse. I know its there because I have driven it in reverse last week. If you pull up on t on the shifter it doesn't do anything. I unscrewed the shifter **** and there is a rod inside not connected to anything. What do I need to do. The car has been setting several years in storage. It's probally something stuck but a shot of WD40 didn't do it ant good.
Old May 10, 2006 | 04:00 PM
Z-man's Avatar
Z-man
The rod in the shifter shouldn't be connected to anything. I suspect your linkage on the transmission itself (under the car) is out of adjustment assuming you have the stock linkage. I can't tell you which way to adjust it, but there is a specific link rod for reverse. You will have to loosen up the nuts on the rod and adjust them in or out until the shifting is better.
Good luck.
Old May 10, 2006 | 04:18 PM
nc98z's Avatar
nc98z
5th Gear
Default reverse
If the rod in the shifter handle doesn't connect to anything how does it function? Is there a spring loaded something or other in the shifter that this thing disengages when you pull up on the T?
Old May 11, 2006 | 12:44 AM
Z-man's Avatar
Z-man
Well, yes. The spring pushes down on the rod which goes into an interlock on the shifter to keep it out of reverse. When you lift it up on the lever, you can move it into reverse. I may have misunderstood your problem. Can you get the shift lever to move into the reverse position and the transmission doesn't go into reverse? Or are you having a problem even moving the lever into the reverse position?
Another thought. The rod should be attached to the t-handle so that it lifts with it. Is it broken?
Old May 11, 2006 | 08:53 AM
nc98z's Avatar
nc98z
5th Gear
Default Reverse
Yes it is seperate from the T part. If it is suppose to attached to the T then it is definately broken. So from what you are saying if I were to remove the rod from the shifter since its already broken it should go over to the left so I can hit reverse?
Old May 11, 2006 | 10:28 AM
Z-man's Avatar
Z-man
Yes it should. If that works, be careful because you can then accidently shift into reverse when you really don't want to (like when you are moving forward or are at a stop and shifting back into first)!!
Old May 11, 2006 | 01:22 PM
nc98z's Avatar
nc98z
5th Gear
Default reverse
Well that explains a lot. I'll have to get the JB Weld out tonight and get this vette back on the road. I bought it for $5,000 and it came with about 2,000 worth of parts and new door seals. I found it in a garage after it had been sitting for 6 years. The guy who bought it had a heart attack and his wife never learned to drive a stick. 84,000 original miles . thank you for the feed back.
To Reverse
