Knocking out lower shock mounts?
Old May 10, 2006 | 10:11 PM
TonySinclair's Avatar
TonySinclair
Default Knocking out lower shock mounts?
I'm contemplating knocking out my lower shock mounts in order to replace the rear struts. How much do I have to disassemble in order to do this? I plan on re-building the entire rear-end next year, but I need to get the wheels going straight up/down now.
It appears the rear spring/bolts are in the way of swinging a sledge.
Any tips are appreciated.
Old May 10, 2006 | 10:15 PM
alotaball's Avatar
alotaball
dont know if this is the proper way of doing .. but i just cleaned the threads and used penetration lube... then used a tie rod fork .. came out pretty easy... but i am sure there is a better way
Old May 10, 2006 | 10:19 PM
luerja's Avatar
luerja
I got lucky and mine just pulled right off...have you tried taking them off yet?
maybe a gear puller can help you out?
good luck,
Jim
Old May 10, 2006 | 11:24 PM
mandm1200's Avatar
mandm1200
How much adjustment is remaining?
The camber is adjusted by the bolts on the opposite end of the strut rod, the end under the differential. If you can hold off until you're ready to do the whole backend by adjusting the current bolts, I think I woild try that first. In my opinion, I would do the rear as one complete project. The shock mounts on mine came out with a few good wacks with a hand sledge. Be careful of the threads.
Old May 10, 2006 | 11:45 PM
TonySinclair
The camber adjustment is too rusted to adjust. Perhaps I'll try disassembling the adjustment end only to clean 'em up...?
A few whacks with a hand sledge...did you have to remove the spring bolts? My spring bolts are in the way of the hammer arc.
Old May 11, 2006 | 12:02 AM
76custompaint's Avatar
76custompaint
We took the spring bolts and spring off, and then went after it with a 10 lb sledge, this was after 2 weeks of soaking them in penetrant. Oh yes, we had to take the torch to them and heat them a bit to get them loose also.
Hope yours aren't in the same shape, It's not a difficult job, but it can take a bit of time.
If you can just take the adjustment apart and clean that part up, that's the way to go, especially if your rubber bushings on the strut rods look good. Ours were crap, and we were going to have to replace them anyway, so we just took the whole thing off at once.
76custompaint
Old May 11, 2006 | 01:51 AM
Greg's Avatar
Greg
Just another Corvette guy
Easiest way, because of the limited room, is with an air chisel, if you have one or access to one, fitted with the hammer bit. Soak 10 minutes with some PB Blaster to penetrate the rust and a couple hits with the air chisel they should pop right out. You won't bash the threads (or your knuckles) this way either like you would swinging a hammer. Hold a piece of flat brass or a brass drift against the threaded end or, lacking that, spin the nut on but stop about an eighth of an inch before the stud is exposed and air hammer the nut. It will crack loose very easily.
Greg
Old May 11, 2006 | 08:57 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You may be lucky and these shock mounts come out after soaking with penetratng oil and a few whacks with a hammer... be careful, get a few nuts that fit the shock mount threads to protect the threads while you beat on them... at $50 each you want to try to safe the shock mounts
There is a "inner sleeve" that is often rusted to the shock mount, preventing it from moving axially towards the front. The problem is that you cannot get the PB blaster (or other penetrating oil) to where it's needed, between the shock mount and inner sleeve.
I used a Dremel and cut the strut rod, then burnt the rubber bushing with a small Home Depot torch... can you say 'McGyver' ???.... then I cut carefully into the inner sleeve and injected PB blaster.
I ended up saving one of the two shock mounts, the first one I tried to get out was destroyed when I used the hammer.
Here are some photos:
Old May 11, 2006 | 09:04 AM
Garys 68's Avatar
Garys 68
I whacked on mine the whole day (did I just say that out loud?), With no results.
Anyway, 10 minutes with a 3 jaw puller and I had them both out. I had the spring off.
Old May 11, 2006 | 09:49 AM
rosslato's Avatar
rosslato
when reinstalling clean em up w/some sandpaper and then apply some antisieze so they'll come apart easy in case u ever have to remove them in the future. mine took 2 hammer hits to pop since i redid em 14 yrs ago
Old May 11, 2006 | 01:01 PM
Wuttin's Avatar
Wuttin
Tony...this worked miracles for me...out in minutes with no damage. Be sure not to twist the shockmount or you may hack up the knurl that helps keep it tight...
http://forums.corvetteforum.com/show...tool+shock+cap
Old May 11, 2006 | 01:18 PM
audiec's Avatar
audiec
Tony, you can also buy the removal tool from the mail order stores. On my 74, I ruined one, saved the other. Check ebay I bought a couple for $15 as spares for my next disassembly. Also, if you are not worried about origional, get the adjustable rods, about $100, they hold really well.
Audie
Old May 11, 2006 | 05:15 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
They can be tough to get out. Make sure you double or triple nut the ends before you "whack" them. If you don't you'll mushroom the threads, and won't be able to get a nut back on them, IF you get them out.
You can also get a piece of pipe, about 1 foot long. Put the pipe over the shock mount threads, and wiggle up and down. That'll loosen them somewhat.
Some come out easy, some are terrible. You might destroy them, and need to buy new ones. You can also heat the "ears" with an oxyacetylene torch. Heat them "cherry red". A propane torch won't cut it. Good luck. It can be an awful job. Chuck
Old May 11, 2006 | 05:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yea it's an awful job alright, after beating on mine for 1/2 hour with a 10lb sledge last fall I gave up, started to get worried about what all that hammering was doing to the bolt on the front of the trailing arm. Still haven't changed the strut rods
Old May 11, 2006 | 06:23 PM
birdsmith's Avatar
birdsmith
I didn't know what 'PB Blaster' was when I did mine, so I used Liquid Wrench instead. I threaded a couple big nuts onto the end of the mount, pulled out the rear spring, and commenced bashing mightily with my mighty 5-lb. sledge. Just as my might began to wane and I thought about quitting, I noticed a sliver of daylight between the shoulder of the shock mount and the upright. With renewed might I continued bashing with great vigor until it was out. Did same thing to other side with no damage. Use the nuts on the threads (unless you wanna pay $$$ for the anti-destruction tool); if you bash directly on the end of the threads with even a brass hammer you run the risk of damaging the threads.
Old May 11, 2006 | 06:43 PM
MotorHead's Avatar
MotorHead
I bought the "anti-destruction tool" it is pretty much destroyed
Old Jun 3, 2006 | 06:34 PM
Tracker's Avatar
Tracker
[IMG][/IMG]
I used a pulley removal tool and a lot of patience to line it up. Once I got the tool lined up I would give it about a quater of a turn and then smack it lightly with a hammer. It took about an hour but the shock mount finally came out.
It worked for me
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
To Knocking out lower shock mounts?
Old Jun 4, 2006 | 08:41 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I went to Auto Zone and bought a large lug nut with the same threads and used it as a removal tool/Thread protector. Be careful with a large hammer, and heating the arm on spindle cherry red. You break or bend thai spindle arm you have a whole new set of issues you don't want anything to do with.
Old Jun 4, 2006 | 09:13 AM
...Roger...'s Avatar
...Roger...
If you are going to rebuild the "entire" rear end next year and you are going to replace the strut rods(not rebuild)and all you want to do is get the wheels straight then just bend the struts upward which will shorten them and bring your wheels in at the bottom.Not the right way but it will acomplish what you want.Put jack in middle of strut and raise up,might have to lean on back of car -dont go too far!!! Ps -dont tell anybody I said this..lol--please forgive me !!!
Old Jun 4, 2006 | 10:01 AM
Red 69's Avatar
Red 69
Tony, below is a link to a thread started a few days ago. The method I used is posted, but I liked the two jaw puller method, if you can get it to work. The fella who used it had very rusted parts, so I am a believer. Check it out!
http://forums.corvetteforum.com/show...1408184&page=2
